moebelhaus Posted August 3, 2014 Share Posted August 3, 2014 Hey Everyone on this beautiful sunday! So, as I am touching pyro for the first time, of course I am using the "Gas Resize Fluid Dynamic" node (from here on out called the "resize node") in my DOP-net to auto adjust the grid size. However, I a getting this slight flicker in the simulation, as long as the container size is being modified by the resize node. As soon as the container has reached its maximum size, and no resizing is going on anymore, flickering stops. Turning off the resizing and letting the container have static dimensions, also eliminates the flicker of course. Anyone out there familiar with this? I tried messing around with the resize-node's "Subtract Threshold" parameter, since it seemed to me (from the help) this might be connected to the problem somehow? But no luck so far.... Thanks for having a look people. resizing active, flickering results before the gridsize comes to rest resize_flikr.avi resizing disabled, no flickering noresize_noflikr.avi -------------------------------- Quote Link to comment Share on other sites More sharing options...
Skybar Posted August 3, 2014 Share Posted August 3, 2014 Does it happen when you are rendering as well? It could very well just be in the viewport. Quote Link to comment Share on other sites More sharing options...
