wateryfield Posted August 28, 2014 Share Posted August 28, 2014 Hi, guys. I get a problem maybe it was be asked before, but i can't find any tips. There is a grid polygon and i add a line on it by add SOP. Is it any way split the grid to two part by the line even the vertex number was not right. I can split it by polySplit or Clip, Break SOP, but they were not flexible enough. Any help will be appreciated! Thanks. grid_split.hip Quote Link to comment Share on other sites More sharing options...
magneto Posted August 28, 2014 Share Posted August 28, 2014 I think you have to write some Python expression for PolySplit SOP to generate the points you want split unless the point numbers to split is fixed. Quote Link to comment Share on other sites More sharing options...
wateryfield Posted August 28, 2014 Author Share Posted August 28, 2014 I think you have to write some Python expression for PolySplit SOP to generate the points you want split unless the point numbers to split is fixed. I think the expression was a great way to do it, i will take a try. Since i not good at python, i look forward someone have a simply way to achieve it. Quote Link to comment Share on other sites More sharing options...
willow wafflebeard Posted August 30, 2014 Share Posted August 30, 2014 (edited) first thought. 1.create a transform and center the grid to the cplane Y 2.create a transform to set the grid parallel to the construction plane Y(if needed) 3.us 2 deletesop extraction left and rightside using >$TX and $TX. 4.add the line in both extraction and use a join sop.for each output. 5.merge them back not so elegant but i think that will give you 2 primitive with the line the center line atop of each other Edited August 30, 2014 by willow wafflebeard Quote Link to comment Share on other sites More sharing options...
wateryfield Posted August 31, 2014 Author Share Posted August 31, 2014 first thought. 1.create a transform and center the grid to the cplane Y 2.create a transform to set the grid parallel to the construction plane Y(if needed) 3.us 2 deletesop extraction left and rightside using >$TX and $TX. 4.add the line in both extraction and use a join sop.for each output. 5.merge them back not so elegant but i think that will give you 2 primitive with the line the center line atop of each other Thank you. Willow. It was feasible, but i think it not not flexible enough. Actually i want split many parts in a SOP once, it seems the polysplit with expression was the best solution. Quote Link to comment Share on other sites More sharing options...
willow wafflebeard Posted September 2, 2014 Share Posted September 2, 2014 the fuse sop has the ability to create unique points in a given group, that may work on splitting, rather than the polysplit your last resort may be the cookie sop Quote Link to comment Share on other sites More sharing options...
