up4 Posted September 22, 2014 Share Posted September 22, 2014 Hi, Now that the 1.0 version of the HtoA plugin is available, I would like to know if there are production-proven rule of thumb for choosing Mantra over Arnold for rendering Houdini scenes (or Houdini Alembic output files). Ideally without starting a flame war. I'm curious to hear from those who had the chance to use Renderman's RIS framework as well. Regards, Vincent Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 22, 2014 Share Posted September 22, 2014 I've heard that Mantra is equal or better than Arnold at some scenes but no details yet - might be still secret sauce. Quote Link to comment Share on other sites More sharing options...
up4 Posted September 22, 2014 Author Share Posted September 22, 2014 Isn't the very essence of Arnold (and PBRT in general) that secret sauce should NOT be a factor? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 22, 2014 Share Posted September 22, 2014 (edited) No, the general theory of PBRT is only part - its the optimising of memory allocation & usage, algorithms etc. Take a look at Marcos talk Arnold. http://www.fxguide.com/fxguidetv/fxguidetv-193-in-depth-with-arnold-creator-marcos-fajardo/ Edited September 22, 2014 by tar Quote Link to comment Share on other sites More sharing options...
up4 Posted September 23, 2014 Author Share Posted September 23, 2014 I saw this interview when it came out. And I remain convinced that the very goal of Solid Angle through their notion of "artist time" economy is the elimination of the necessity of secret rendering tricks. And that less bias means less saucy tricks. And that unbiased means no sauce at all, only cinematography be it in-camera or not. Anyways, until we get realtime PBRT (and we are getting closer with NVIDIA's newly released Maxwell GPUs), I know there is a place for bias and rendering tricks. And that would be a reformulation of my question: with Arnold around, (exactly) when is the use of Mantra and its rendering tricks still required (and for how long) in the Houdini ecosystem for photorealistic cg in movies? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 23, 2014 Share Posted September 23, 2014 I'm not using Arnold yet but AFAIK they are equal rendering technologies. Can you explain the 'tricks' bit? ie. Arnold has no caustics, but Mantra does by using a 'trick' Arnold has simplified the UI but Mantra shaders are a simple UI too. Quote Link to comment Share on other sites More sharing options...
Annon Posted September 23, 2014 Share Posted September 23, 2014 I haven't used Arnold Houdini since it's very early conception, but know people who use it in production. The general consensus seems to be that using "ass" files is useful for setting up pipeline between houdini artists and maya lighters. Arnold handles A LOT of points with instancing and hard surfaces/points are a no brainer. Mantra volumes are simply better. I don't like not having complete control of the shaders and love tricks... C 1 Quote Link to comment Share on other sites More sharing options...
pezetko Posted September 23, 2014 Share Posted September 23, 2014 To get some reasonable rendertimes I'm using some tricks in Arnold (for XSI) too (separating environment reflection from env. lights), turning off some ray types for some objects based on materials/details etc. to speed up rendering. Ass files are good for compatible pipeline and speeding up scene compilation/conversion time. Arnold needs simple shader networks to benefit from high speed. Quote Link to comment Share on other sites More sharing options...
up4 Posted September 23, 2014 Author Share Posted September 23, 2014 So all of this kind of confirms the impression that one currently gets: the balance between lookdev/lighting effort vs. render time vs. accuracy is something that Arnold is generally nailing best at the moment. And one should look for Mantra's output at lookdev time for specific situations like things requiring bidirectional path tracing (like caustics) or for which Mantra was designed to be better at being Houdini's internal renderer (mostly volumes, but also maybe also anything FXish). And deep-composite everything later in Nuke with Peregrine Labs' Bokeh. Or something like that. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 23, 2014 Share Posted September 23, 2014 Mantra isn't bidirectional afaik. I would dig deeper and look at sss features too. Indirect sss in particular. It'd be worth doing a step by step feature parity test to really nail this. Thus far in testing Arnold for houdini is a v1 for sure, at least on OS X. Ipr makes houdini jerky and changing lights or textures seems to require you to stop start Ipr iirc. Quote Link to comment Share on other sites More sharing options...
up4 Posted September 23, 2014 Author Share Posted September 23, 2014 So, how does Mantra do caustics if it isn't bidi. Like Arnold? https://support.solidangle.com/display/mayatut/Refractive+Caustics As Marcos says in the interview, caustics look good and all, but are rarely required in production (the moonlit interior pool with white walls scenario). I agree that ipr integration is broken (I also tested on Mac only for now). But I have access to Linux and Windows machines too. Can we agree on benchmark hip files (more evolved than the Cornell box) for which there would be both Mantra and Arnold versions and we test for speed and post screenshots? Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted September 23, 2014 Share Posted September 23, 2014 One big reason for using Mantra is that it's a hell of a lot cheaper than arnold. You can also get the same result with Mantra as Arnold if the artist knows what he is doing. SESI just needs to spend some more time on usability and documentation so that people can easier get started. They also need to stop making up their own names and just call stuff what artist are used to it being called. Reflection and refraction angle makes sense if you have studied a lot of math but for your average vray/arnold ligher they have no idea. They are looking for glossiness/roughness. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 23, 2014 Share Posted September 23, 2014 Im going to start with informal testing to get familiar, then more structured. Re naming. No way I hate the idea of conforming to other so called standards. Angle is as complex as other terms upon analysis. Quote Link to comment Share on other sites More sharing options...
eetu Posted September 23, 2014 Share Posted September 23, 2014 In my opinion the angle is clearly more obvious than the "usual" glossiness/roughness/smoothness values. The ranges tend to differ between applications, and it's often quite hard to find out what the values actually correspond to in the real world. And when you do find out they are often defined as something like variance of microfacet normal vectors (square of standard deviation), which is far more abstract than the angle. Then again, being the odd one out does incur a price - but with Houdini we're the odd one out in any case... Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 23, 2014 Share Posted September 23, 2014 To get the ball rolling - here's a 2 min crap test of SSS in Mantra vs Arnold - no time to check the settings; tried just go with SSS sans diffuse - doesn't look right but hey, let's start testing! IndirectSSS.hip.zip Quote Link to comment Share on other sites More sharing options...
panupat Posted September 24, 2014 Share Posted September 24, 2014 Sorry for a bit off topic. Does HtoA allows us to use it without license but with watermark like in other applications? I really want to play with it. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 24, 2014 Share Posted September 24, 2014 yup - just need a full license - not indie or apprentice. Quote Link to comment Share on other sites More sharing options...
panupat Posted September 24, 2014 Share Posted September 24, 2014 Oh... in that case I can only play with it at work then Quote Link to comment Share on other sites More sharing options...
up4 Posted October 2, 2014 Author Share Posted October 2, 2014 So, with all being said. I tried some examples from the Arnold support site. And the least I can says is that the integration into Houdini is not seamless right now. For the time being, I will stick to Matra and wait a little longer for the Arnold plugin to mature a little more and compare the two. Quote Link to comment Share on other sites More sharing options...
kikou Posted October 2, 2014 Share Posted October 2, 2014 So, with all being said. I tried some examples from the Arnold support site. And the least I can says is that the integration into Houdini is not seamless right now. For the time being, I will stick to Matra and wait a little longer for the Arnold plugin to mature a little more and compare the two. Hi up4, I'm the main developer of HtoA. I won't deny the plugin has some rough edges, and it will take some time for the integration to be as good as Mantra, obviously. For this reason, I'd be most interested in getting feedback, good or bad, to assess where we should focus our efforts. Could you please detail the issues you encountered during evaluation? Of course, I extend this request to anybody who wants to share any feedback on HtoA and Arnold. I don't want to hijack this very interesting topic, so you can PM if you prefer. Quote Link to comment Share on other sites More sharing options...
