[H13] Light component separation
Hi guys,
i have a question concerning light components in H13. I have the following case:
I want a light that only contributes to direct diffuse illumination.
According to the documentation it should be possible with the category syntax to do just that, however i cannot seem to get it working.
Here is the use case: The candle on the table has no illumination. The illumination comes from a sphere light. The sphere light has indirect contribution turned off because of noise issues. However the sphere light still contributes to direct reflection, where only the pyro sim should contribute. I cannot seem to dissable everything but direct diffuse on the sphere light....
Edited by timmwagener
I think the image shows how to solve your problem...
(sorry, in the image, I disabled the diffuse. You need to do the opposite, disable all the other components)
post-7461-0-24688700-1415024510_thumb.jp
Edited by gui
Hey gui, thx for your reply, but i think you are disabling both the indirect and direct diffuse component.
What i need would be something like
[ ]indirect
[ ]* ^diffuse
or
[ ]indirect & * ^diffuse
The thing is that i didnt find a syntax that would work. The component syntax always became invalid and all contributions where enabled again.
