Pretty horsey
Hey; cool :) So I guess that means that it works with build 142 ??
BTW; both Mark Elendt's and my shader need surface normals to be well defined over the whole object (specifically; the point cloud needs proper normals -- there's no frontface() trickery possible with the cloud). Additionally; both shaders need the ptarea attribute (scatter sop) defined -- taking the "Maximum" over 4 samples is probably the best choice for mine.
(I just mention the normals, because I think that's what is causing the flipped boundary along the center-front of the neck... but it could be somethng else).
Cheers!
13305[/snapback]
I'll take a look and see... I believe the normals are ok, but then you never know :)
Thanks
Marc
  stevenong said:
Thanks to you & JC for releasing the SSS pack! :notworthy:
Just so you all know, Mark Elendt released his variation on the SSS shader. Take a look at the pinned topic under Rendering if you like alternatives... The fast ambient occlusion is pretty cool too.
