vfxlearner Posted December 16, 2014 Share Posted December 16, 2014 Im getting lot of points while rendering volumes(mantra).Can any one help me with this Quote Link to comment Share on other sites More sharing options...
Mandrake0 Posted December 16, 2014 Share Posted December 16, 2014 (edited) use micropolygon render and set the volume quality to 1 (mantra node) that should help you. edit: maybe it would be nice to see the hip file it could be also something else. Edited December 16, 2014 by Mandrake0 Quote Link to comment Share on other sites More sharing options...
eetu Posted December 16, 2014 Share Posted December 16, 2014 Adding Stochastic Transparency Samples (mantra->Properties->Sampling) or disabling them altogether should also help - at the expense of render time of course. Quote Link to comment Share on other sites More sharing options...
vfxlearner Posted December 16, 2014 Author Share Posted December 16, 2014 Thanks for the info guys but its not working,I did upload the file.Please kindly check it . Volume.hip Quote Link to comment Share on other sites More sharing options...
eetu Posted December 16, 2014 Share Posted December 16, 2014 Taking a quick look, either of our suggestions seem to help. (Remember that the Render View panel always uses raytrace if it's set in preview mode) 1 Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted December 16, 2014 Share Posted December 16, 2014 If you are using PBR, I would recommend increasing your pixel samples to at least 6X6. this will get rid of most of the noise. that will get you really close, then I personally would lower the noise level to 0.01, and raise the volume quality to 1. Quote Link to comment Share on other sites More sharing options...
vfxlearner Posted December 16, 2014 Author Share Posted December 16, 2014 I unselected the preview off and it worked like a charm,thanks for the tips guys .Id like to know about pbr it seems intresting one ,can any one help me by giving a brief about it Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted December 16, 2014 Share Posted December 16, 2014 Here is a good read on what PBR is. http://www.marmoset.co/toolbag/learn/pbr-theory When it comes to rendering volumes PBR may be a bit slower than micropoly but will give you much greater detail than you could ever get with micropoly rendering. Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted December 16, 2014 Share Posted December 16, 2014 How are you lighting your volume? Quote Link to comment Share on other sites More sharing options...
vfxlearner Posted December 16, 2014 Author Share Posted December 16, 2014 I used skylight for lighting the volume Quote Link to comment Share on other sites More sharing options...
vfxlearner Posted December 16, 2014 Author Share Posted December 16, 2014 Hey Sierra62 ,the page you have sent about pbr theory is not shown or invalid,Can you resend it again? Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted December 16, 2014 Share Posted December 16, 2014 Personally I have found that more of a 3 point lighting setup along with an environment light with HDR map (default sky environment map works well too) will give the best results. When using a single light, it tends to result in a flatter image than a multi light setup. http://www.marmoset.co/toolbag/learn/pbr-theory hopefully that works this time. 1 Quote Link to comment Share on other sites More sharing options...
vfxlearner Posted December 16, 2014 Author Share Posted December 16, 2014 Yeah it worked,thanks for the Cool info there Quote Link to comment Share on other sites More sharing options...
iamyog Posted December 16, 2014 Share Posted December 16, 2014 (edited) Personally I have found that more of a 3 point lighting setup along with an environment light with HDR map (default sky environment map works well too) will give the best results. When using a single light, it tends to result in a flatter image than a multi light setup. Careful with the Environment Light with volumes. It kills your render times and can usually be efficiently replaced by a quick lighting job. Old school explanations here are gold : http://forums.odforce.net/topic/6143-how-do-i-optimize-my-volume-lighthing/?p=40892 Edited December 16, 2014 by iamyog Quote Link to comment Share on other sites More sharing options...
