Fluid From Object Won't Remain In FLIP Tank?
Atom
Hi All,
I am trying to make a simple body of water, derived from a cube, splash around a medicine bottle.
I created a FLIP tank to be the domain for the simulation. The bottle mesh is a rigid body object. I placed a cube in the FLIP tank as well and converted it to fluid to be the initial fluid for the tank.
However, this does not work. The cube of fluid I created just falls out of the tank and does not recognize the walls of the FLIP tank. Does anyone know how to fix this problem?
How do I let the fluid object know it is a participant in the FLIP tank?
Thanks
ap_bottle_splash_1a.hipnc
You have created two separate FLIP simulations. (two FLIP solvers)
The first one has an empty initial object, but correctly set closed boundaries and a resized domain.
The second one has your cube as initial data, but does not have closed boundaries and has the default domain extents.
You could e.g. delete "fliptank" and "filpsolver2" nodes and connect your flipfluidobject1 to flipsolver1
Thanks for the tips, I wondered about the multiple solvers. I thought Houdini just simply summed all that because the result gets routed to a single node. If I delete the FLIP tank and flipsolver2 my inital fluid just falls through the floor, no boundaries.
In this example I have created cube based walls, an RDB floor and the bottle all as rigid body participants. This does keep the fluid inside the required area but I still can not get the fluid to avoid the bottle in the scene...
ap_bottle_only_1b.hipnc
post-12295-0-74277000-1421687660_thumb.j
Edited by Atom
Ah I forgot to specify that you should enable "closed boundaries" on your flip fluid object.
For the bottle, your flip resolution is so low that the bottle doesn't resolve well into the collision field of the fluid sim. Even if an object's own collision volume representation looks fine, you should always check how it looks like in the collision field of the simulation/solver.
post-2678-0-78091800-1421689284_thumb.jp
I am still learning the FLIP system. So to increase fluid resolution do I decrease particle separation? Or is there another setting for turning up the fluid resolution?
Yepp, exactly that. The volume resolution is Grid Scale * Particle Separation, so in your scene the individual underlying voxels are 0.2*0.2*0.2 in size. Your bottle is 0.19*0.69*0.34 in size, so it is no wonder the simulation does not see it properly.
Also, if you MMB over any node in the dopnet, you will see that the overall resolution of your sim is 22*14*14, which is quite low.
Edited by eetu
