Vector Field FX with LIC Method.
Hi Guys,
I would like to achieve this kind of effects inside H.
http://roberthodgin.com/additionsubtraction/
http://roberthodgin.com/wired-magazine/
Basically it looks that it is a Vector Field Visualisation using LIC Methods + Color remapping.
The concept is describe here :
http://en.wikipedia.org/wiki/Line_integral_convolution
http://web.mit.edu/viz/EM/visualizations/resources/cabral.pdf
I would be curious to get some expert POV on the most efficient and straightforward way to achieve this in H.
- Full VEX ?
- POP ?
- DOP ?
Any input or previous Hip reference of something similar would be great !
Thanks for your lights ! :)
Cheers
E
Edited by sebkaine
Guest mantragora
There was even article about this. It was around the time when Houdini got first Volume DOPS, so around 2010.
I remember him because he had one of the first websites that used this cool Microsoft Labs technique for zooming big images (you all know it probably from Google Earth). I exchanged couple words with him so I now that he used OpenZoom project for displaying his gallery. Maybe someone remembers him?
I did similar technique to generate these
http://www.popkafx.com/wp/?cat=6
post-12879-0-65204300-1423512658_thumb.j
I originally tried to advect many particles through a static velocity field and made connected trails but ended up using the volume trail sop to generate the lines in a cheaper fashion.  To get the high fidelity output I would resample these trails and stamp them to a volume.
Some of the volumes were over 2k resolution so I would iteratively generate new lines and add them to the high-res volume at small particle scale.
At render time I would use a ramp based on density to create color variety and tweak the values post-render.
Edited by icarus
  • Like 3
Thanks a lot for all your feedback guys ! :)
@Raymond very cool result
@Martin your setup is extremely cool ! very light, no computation, very beautiful result ...  i love it ! :wub:
@Mantragora the occluded rendering are extremely elegant ... great ref
I think i will try to mix an hybrid approach with particles and curves. If you have any other ideas or tricks i am still curious.
I think one important aspect is to be able to
- create animated force field that evolve throw time , with expension / retraction / vorticity of the several fields
- normalise the vectors of the field generated
- generate curves that follow those vectors
- generate particles that propagate along those vectors
- keep simulation time very low / very fast
A mix of cv+point could be cool for the rendering !
some cool links :
http://web.cse.ohio-state.edu/~hwshen/hwshen/FlowVis.html
http://www.paraview.org/Wiki/ParaView/Line_Integral_Convolution
http://www.zhanpingliu.org/research/flowvis/flowvis.htm
Edited by sebkaine
 you might also want to look into the vdb advect points sop.  There is a pretty good example of how to use it on the open vdb site. under "examples.zip" : http://www.openvdb.org/download/
 -G
some cool links :
  • Like 2
