"spherical linear interpolation" when blending primitive trans
Netvudu
Hi there.
The journal reads
Houdini 14.0.215: The Blend Shapes SOP and Time Blend SOPs now have an option to use spherical linear interpolation when blending primitive transforms.
Thanks to this change, some time warps with packed primitives that were badly deforming the copies now work seemingly well.
Can anybody explain what´s this and what´s going un under the hood. Wikipedia hints this is related to quaternion rotations but I could certainly take a specific explanation to what´s going on there.
Quaternions can represent a rotation, just like Euler angles. Blending the 2 sets of 3 Euler angles individually often shows bad flipping and weird twisting rotations, whereas spherical linear interpolation with quaternions just "does the right thing" and takes the shortest path between two orientations.
Spherical Linear Interpolation basically forms a plane between the two orientation vectors (imagine two vectors pointing down Z in each orientation, like a lookat vector) such that both lie on that plane. Then, it interpolates between those 2 vectors such that they all lie along the shortest arc between those vectors on that plane. The "twist" around each of those vectors is interpolated as well. I can show you the math if you like, but that's easy to search for and not nearly as easy to grasp :)
I didn't implement it, so I'm afraid I can't really answer the implementation-specific details (just drawing on my knowledge of slerps from my CHOPs days). My guess is that it's off to maintain backwards compatibility, so loading an H13 file into H14 doesn't produce different results. It'll be slower than normal interpolation as well, but I don't think that's the reason it isn't enabled.
Slerp alone does not always produces shortest path, so I assume there are some dot product checks to ensure that.
