Hair revisited
Marc
You can download Houdini Apprentice from here
http://sidefx.vislab.usyd.edu.au/
and get free everything! Renderer the works. Completely compatible with the full Houdini.
I'm slightly confused how you converted your functions to VEX without it though, so maybe this isn't what you mean.  ;)
15647[/snapback]
Ha ha... :) The answer is pretty simple ! I did a renderman (sl) version and since both shading languages (VEX & sl) are almost identical, there was almost nothing to do ! :)
OK, I
  • 2 weeks later...
I've read this whole thread and am a bit concerned that getting cartoony hair on my cartoon monkey is going to be a whole lot more complicated than I could possibly have imagined...
:blink:
15829[/snapback]
That depends on the number of hairs, the shading will not be the problem ! :)
Arno
Someone needs to make a quick OTL to calculate the maj_axis that Arno was talking about in the fur/fibre/hair thread still.  I'd try it but I'm slammed right now.
Take care,
Jason
15840[/snapback]
Im not shure if I
some frames from the hairball: rendered with the latest version from spice, 5000 hairs, 2 lights.
15864[/snapback]
Thanks Mike,
just two questions:
1.) Where are the light sources ?
2.) Did you set the major_axis vector correctly ?
The result look a bit different from my proprietary renderer. Could you try version 1.1 please ?
Thanks a lot !!!
Arno
arno_hair_far_field_v1_1.zip
You mean something like this?
(VEX Major Axis SOP generated from VOP net)
15863[/snapback]
Thanks a lot Edward,
the code looks right (But I dont know how to use it with Houdini) !:)
Of course the semi major axis is following the geometry now without variation. For realistic results one has to perturb a bit . Therefore I will add some code to this otl...
Cheers !
Arno
Theoretically, one should be able to just append the SOP to the geometry, set it the render flag on it and render away.
However, I tried it with the shader and it didn't seem to work. Perhaps you didn't put the "export" keyword in the shader function declaration for the parameters which can be per point?
Since you want to modify it, I've included the .hip file that was used to create the .otl file.
major_axis.hipnc.gz
This shouldn't be necessary - the export keyword is only to tell Mantra to keep the information around for writing to Deep Raster layers. Any parameter in a shader can be overriden by geo attributes without any extra effort on the part of the shader-writer.
Perhaps I'll get a moment this weekend to play with this! :)
Take care,
Jason
