Get polygons in VEX
I have some geometry with a few number of color polygon pieces. In VEX we can simply detect this polys by color attribute value.
But I need to detect only single color piece (by poly number for example).
So I want to see something like connectivity\partition but in VEX implementation.
Any ideas?
Edited by Alexey Vanzhula
Is there a specific reason why you cannot use a connectivity SOP? you can of course just query the attrib generated by the connectivity sop in VEX,]
you can also consider promoting your prim color attribute to a vertex attrib and then use the vertexsplit SOP (and possibly a connectivity afterwards)
Thanx for reply!
Need some fast solution to detect color poly patches on geometry without deleting geometry (connectivity/partition).
Of course  we can add attribute with connectivity SOP, delete other pieces and detect what piece of this color we need. But it slow.
I need fast solution for interactive tools.
Create some objects like this that has Cd prim attribute and add Connectivity for prims before AttribWrangle:
In AttribWrangle (Detail mode) use this to color prims that has class attribute value of 3. This is not the best way to do this but I am just showing it as an example to get all the primitives that has the same attribute value.
int targetprim = 3;
int count = findattribvalcount(0, "prim", "class", 3);
for (int i = 0; i < count; i++)
    int primindex = findattribval( 0, "prim", "class", targetprim, i);
    setattrib(geoself(), "prim", "Cd", primindex, -1, {1,0,0}, "set");
The result should be like this:
Good example. But i need this: http://i.imgur.com/M8eRdDH.png
As you can see prim with id=840 have a red color in red island. Also this geometry has other red piece. I need only prims in red island form prim with id=840.
Sorry for bad topic description :) Still have a bad english :(
Guest mantragora
Wouldn't it be easier if you just made a group from each colored island and check did any of those groups contains interesting you primitive id? That way you wouldn't had to loop thru it.
Guest mantragora
1. First Pass = ConnectivitySOP + PartitionSOP.
2. Second Pass = ForEach set to group and again ConnectivitySOP + PartitionSOP. You will have to name groups here correctly so it wouldn't return again back two groups.
3. Check which group contains your primitive.
Edited by mantragora
One blast, one connectivity, one attribtransfer and couple of wrangles.
There is no need for partition sop and foreach sop.
(There is foreach example included. That one grows the starting group until the inclusion of the whole color island. But it's too slow, and fail in certain situation).
Solution with blast looks much more stable and faster.
pz_wrangle_prims_example.hipnc
Edited by pezetko
if you promote "Cd" from primitives to vertices you could use the vertexSplit-sop to partition the geometry into seperate parts. after that you can select the different islands in the viewport by using 3d connectivity. should also be quite fast ...
hth.
petz
  • Like 2
