UPDATED.
If some image doesn't load, just refresh the page. Dropbox isn't too reliable unfortunately. I chose it as a medium over forum's upload mechanism only because the latter seems to compress images on its own, which I do not want.
Two master shots:
nuts_and_bolts_master.jpg?dl=1
nuts_and_bolts_take2.jpg?dl=1
And three detail shots:
nuts_and_bolts_take1.jpg?dl=1
nuts_and_bolts_take4.jpg?dl=1
nuts_and_bolts_take3.jpg?dl=1
What was done in Houdini:
Some modelling of base shapes (blades of both fans and all tubular shapes of the CPU cooler - some of which are not visible on this particular shot) and instancing of similar meshes; RBD simulation for realistic placement of all those nuts and bolts; rendering (Mantra); postproduction.
Other software used:
Nvil - subdivision modelling of all objects.
3D-Coat 4.5 BETA - UVs and texturing of all objects (but the floor).
Bitmap2Material 3 - generating PBR textures of the wooden floor.
Photoshop - tweaking displacement map of the floor (painting the spacing between the boards); stencils for texturing in 3D-Coat; post.
Took over 7 hours (edit: per shot) to render on a 3930K... :o Mostly because of those blasted semi-transparent motherboard rivets...
Old, flat image can be accessed here: https://www.dropbox.com/s/vjbje6vcz2o8k4r/nuts_and_bolts_cam1_final.jpg?dl=1
Edited by ajz
  • Like 6
Very cool piece! I'm curious about how you approached the modeling and simulation of all those tiny little screws and bolts. Is everything modeled to real-world scale or just in arbitrary units and you're tweaking the solver to get the correct behavior? It seems like even a very robust dynamics system could have trouble accurately simulating such small objects, so I'm very interested to hear what your experience with it was.
Thank you all for heart-warming comments. :)
I wouldn't mind hearing some critique too, in order to know what I should pay more attention to in the future.
I modelled all objects in arbitrary units and then scaled those objects to fit each other's size inside Houdini. Initially I made the scene to match real-world scale, but due to one problem (unrelated to DOPs) I had to crank up the scale a lot, so now the cooler measures 28 meters in height... However, because the goal of the project was a still image, this didn't matter much for the simulation, which I needed only to scatter objects around the scene in a semi-random fashion.
For the purpose of the RBD simulation I replaced all moving models (nuts, screws, washers and motherboard rivets) with their modified low-poly versions. I tried to make them as much convex as possible, while still keeping their overall shape. I used meta balls field mode in their DOPs, and a mixture of volume and ray-intersection modes for DOPs of static colliders. 1/6 Min/Max substeps and an aggressive auto-freeze DOP were enough to make the simulation fast and quite accurate. Generally speaking, I didn't have to do a lot of tweaking to DOPs. Most of them are almost at their defaults. I believe that most time I have spent tweaking meshes of colliders rather than fiddling with DOP parameters.
Objects settled down after about 160 frames. I don't remember exactly how much time it took to solve the simulation, but I think it was something under 20 minutes.
A critique is that it's could be much more interesting as a photograph in composition and lighting. Shoot it with different lens and angle and lighting. i.e. practice with a real camera on a similar setup perhaps:
Keith Johnson explains this in his recent excellent Houdini work: @ ~39:29
'Houdini - Neon Sign - Part 2'
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=38375
Edit: JIT! As of H14.0.307 there are IES profiles for lights included in $HFS/houdini/ies  :)
post-8321-0-00702200-1429765945_thumb.jp
Edited by tar
This was an excellent video and a good piece of advice. Thanks Marty!
I'll be experimenting with different lighting conditions and some detail shots today. I am most definitely going to check out those IES profiles. I'll see if I can come up with something more interesting.
Until then, here's the same rendered image, but with some heavier post. Hopefully I didn't overdo it.
nuts_and_bolts_master_shot.jpg?dl=1
Okay, finally the rendering has finished. I edited my initial post to include new images. I hope they're more interesting than the original one.
PS. Sorry for large dimensions, but I'm not sure if it's possible to use thumbnails on the forum. :blush:
Edited by ajz
