I need math terms in Houdini (secant)
jingaa
Hello everybody, i was trying something and needed a secant term (in math) as a vex or expression....
secant use value between 1.5 and 5
for example: There is a line and i am gonna give a twisting if i use sin it will be between -1 and 1 so i must use expression that must be between 1.5 and 5 or less. So, secant in math is makes that.
how i can make, anybody has an idea?
Thank you for taking your time...
If sin works otherwise, just fit the range to whatever you want. In VOPs use the Fit Range VOP, if you're writing an expression then 1.75*sin() + 3.25 gives values between 1.5 and 5
