dayelov Posted June 20, 2015 Share Posted June 20, 2015 Suddenly my houdini starts to save a .hipnc files instead of .hipI choose filename and .hip eextension but file saves as .hipncNeeds help. Thanks Quote Link to comment Share on other sites More sharing options...
dayelov Posted June 20, 2015 Author Share Posted June 20, 2015 or how can I open that .hipnc file and do not enter into non-commercial mode? Quote Link to comment Share on other sites More sharing options...
davpe Posted June 20, 2015 Share Posted June 20, 2015 if houdini saves hipnc instead of hip it most likely means you could not obtain commercial licence and houdini is in non-commercial mode (you can see it on splashscreen and on the top bar of the application window). you cant open hipnc with commercial license. you will have to transfer all work manually from one scene to another. Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted June 21, 2015 Share Posted June 21, 2015 Hmm... I wonder, if you would bake your Hipnc to 123.cmd file with a help of opscript command, what would happen if you would then run full commercial Houdini with this file? Will it open Houdini still in NC mode? Quote Link to comment Share on other sites More sharing options...
michael Posted June 21, 2015 Share Posted June 21, 2015 this happen to me all the time... I'm running Houdini but I open a hipnc file to have a look at it, usually a file posted to the forums, and then I move on - forgetting that I'm still in NC... Quote Link to comment Share on other sites More sharing options...
pbarua Posted June 22, 2015 Share Posted June 22, 2015 or how can I open that .hipnc file and do not enter into non-commercial mode? You can't do this. use opscript in hscript or hou.Node.saveChildrenToFile() in python. Quote Link to comment Share on other sites More sharing options...
dayelov Posted June 22, 2015 Author Share Posted June 22, 2015 Thanks guys Quote Link to comment Share on other sites More sharing options...
blendingshadow Posted March 1, 2016 Share Posted March 1, 2016 You can't do this. use opscript in hscript or hou.Node.saveChildrenToFile() in python. Will this convert .hipnc files to .hip ? 1 Quote Link to comment Share on other sites More sharing options...
archz2 Posted June 29, 2022 Share Posted June 29, 2022 On 6/22/2015 at 3:51 PM, pbarua said: You can't do this. use opscript in hscript or hou.Node.saveChildrenToFile() in python. What is the procedure to do this? Where exactly do I have to enter this command? I came to this thread while searching for the method to convert hipnc to hip. Quote Link to comment Share on other sites More sharing options...
