Save .hipnc instead of .hip
if houdini saves hipnc instead of hip it most likely means you could not obtain commercial licence and houdini is in non-commercial mode (you can see it on splashscreen and on the top bar of the application window). you cant open hipnc with commercial license. you will have to transfer all work manually from one scene to another.
Guest mantragora
Hmm... I wonder, if you would bake your Hipnc to 123.cmd file with a help of
opscript
command, what would happen if you would then run full commercial Houdini with this file? Will it open Houdini still in NC mode?
  • 8 months later...
  • 6 years later...
  On 6/22/2015 at 10:21 AM, pbarua said:
You can't do this.
use opscript in hscript or hou.Node.saveChildrenToFile() in python.
What is the procedure to do this? Where exactly do I have to enter this command? I came to this thread while searching for the method to convert hipnc to hip.
