sandy_maith Posted June 27, 2015 Share Posted June 27, 2015 (edited) Hi How can i improve this shot just to look it move natural movement..somehow i'm not able to control the repetitiveness of the waves... i want to make it more natural looking like by carlos parmentier. This is my first test with houdini and pls bear with me if i'm missing some obvious things here...i tried my best and still on it.. Thanks sandy beach_10.hipnc beah_waves.mov Edited June 28, 2015 by sandy_maith Quote Link to comment Share on other sites More sharing options...
Diego A Grimaldi Posted June 30, 2015 Share Posted June 30, 2015 Have you tried using the Beach Tank shelf tool? That will get you to a good point just with a click. A lot of the natural motion comes from the ocean spectrum movement. And trust me the first time you try to make a beach wave it won't look as great as Carlos', I speak for experience He's a very experienced and talented artist. Good luck! Quote Link to comment Share on other sites More sharing options...
polterizer Posted July 1, 2015 Share Posted July 1, 2015 I agree with diego, and thank you diego for the good words Ill try to help you to make beachwave, first of all you can seek my tutorial , i made my beachwaves with this method but you can try the beachtank as said Diego, i think works very well! just click and test, you will see the results and pratice it for make your own beachwave terrain. hope that helps and keep it up! cheers Carlos 2 Quote Link to comment Share on other sites More sharing options...
sandy_maith Posted July 1, 2015 Author Share Posted July 1, 2015 (edited) Pls dont misunderstand..i'm not trying any shortcuts here.. Great to hear from u carlos and thanks Diego....the reason why i didn't use beach tank is i wanted to set it up on my own.... I've seen this tutorial many time Carlos and i'm using this method only one thing i fail to understand... What does size and center does in ocean evaluate node, under volumes .....there is no visual representation of that and i understand from another video of Carlos and some try and error that its does play an important to get good waves.. Did you use any other force other than ocean spectrum? Thanks Edited July 1, 2015 by sandy_maith 1 Quote Link to comment Share on other sites More sharing options...
deniz Posted July 2, 2015 Share Posted July 2, 2015 (edited) for the sdf you get a visual representation of it, if you name the density field as surface in a volumevisualtization for exemple, uniform sampling should be "by size" in the volumes tab , for the velocity you can use a volume trail ,you can dive into the ocean spectrum and change the "calc_amplitude", "calc_frequency... and "calc_amplitude..normalize ." volumevops for adding your math/noise whatever for your owen ocean spectrum by creating a sdf with your "ocean spectrum" surface field and your custom vel, will be a good start i guess for building it from scratch but the ocean shelf tools are looking really complicated Edited July 2, 2015 by deniz 1 Quote Link to comment Share on other sites More sharing options...
polterizer Posted July 2, 2015 Share Posted July 2, 2015 (edited) Hey, there is my file of the old beachwaves v2, you can see and test it . enjoy! beachwaves_v2_config.hipnc example: https://vimeo.com/72972103 cheers Carlos https://vimeo.com/user2149850 https://www.facebook.com/Carlosparmentier Edited July 2, 2015 by polterizer 4 Quote Link to comment Share on other sites More sharing options...
sandy_maith Posted July 3, 2015 Author Share Posted July 3, 2015 Thanks a lot Carlos for the file..Thats so very generous of you... Will try to understand and come back with the results soon... 1 Quote Link to comment Share on other sites More sharing options...
sandy_maith Posted July 4, 2015 Author Share Posted July 4, 2015 Ok..so i was able to reach here with the waves... The only issue i'm not able to fully understand so far is how the size (under volumes) in ocean evaluate node actually works.. Also how can offset the waves or break the repetition is also not clear so far ... Thanks Sandy waves.mov 1 Quote Link to comment Share on other sites More sharing options...
sandy_maith Posted July 4, 2015 Author Share Posted July 4, 2015 Hi Carlos In your file size values in ocean evaluate node are being referenced from size of the fluid tank..also there are some other values are getting referenced too.. Could u pls share the reason behind this, specially referencing size value? I'm getting very different results when i tried this. Thanks Sandy 1 Quote Link to comment Share on other sites More sharing options...
sandy_maith Posted July 7, 2015 Author Share Posted July 7, 2015 A little study on how ocean evaluate size effects flip fluids.......some more doubts to clear........will come back soon.. wave_size.mov 1 Quote Link to comment Share on other sites More sharing options...
sandy_maith Posted July 29, 2015 Author Share Posted July 29, 2015 Hi all First of all, i'd like to thank carlos parmentier for his support and sharing his techniques........ I'm back with a lot of learning r&d and with some results off course...here's the result https://youtu.be/mc8CZJY95xk I'd really appreciate to have your views on this and how to make it better....right now i'm learning to create wetmaps, textures, lighting and other stuff to finish my first shot in houdini.. Thanks all 1 Quote Link to comment Share on other sites More sharing options...
Navneet Arora Posted July 29, 2015 Share Posted July 29, 2015 I think the overall speed is too less , looks like a ramped scene. You should increase the timescale 1 Quote Link to comment Share on other sites More sharing options...
