[solved]Can't render particle in Houdini 14
Hi there,
Recently I followed CGS's fluid FX tutorial and tried to use Addpoint vop to achieve a foam effects. Everything goes well expect the rendering. After I tried a couple of times I found I could only render out the source particles which directly generated by pop netwok. Those points( I assume those are particles?) which generated by addpoint vop could not be rendered. So I just tried to render some test I did before I still get the same result. you can see problem pictures as following:
this is my network, Point_add attribute vop response for adding points.
post-4595-0-76776700-1436944323_thumb.pn
this is how it looks in view port
post-4595-0-13266900-1436944317_thumb.pn
this is the render
post-4595-0-20549900-1436944329_thumb.pn
simple file attached. your help is much appreciated!
Regards,
Gu
problem.hip
Edited by GrayHare
Hi Gray Yu!
It is working just fine, make sure the pscale attribute is the same for all the particles. And yeah, try not sending files with take overrides and so on.
I copied your scene and just had a quick look. It worked just fine.
EDIT* Btw, your render-flag was on the grid hence you were only rendering it and not the particles.
Cheers
addPoint_render_huds.hip
Edited by Hudson
