Pancho Posted July 29, 2015 Share Posted July 29, 2015 Sorry to bother you guys/girls again. But I'm stuck again. Not speaking Houdini fluently yet and need a translator all the time. : ) The loop slice in Modo lets you select some polys and then it cuts through them. I need the same functionality in H14. Select a loop, determine how many edges I want to add and then get the result. I did search the web, but couldn't find anything. Stumbled across the PolySplit node, but it lacks all the inputs I would suspect to get with such a compound. Can somebody point me please in the right direction? Cheers Tom Quote Link to comment Share on other sites More sharing options...
magneto Posted July 29, 2015 Share Posted July 29, 2015 Edge Divide SOP does what you need, if you can find the inner edges of you poly selection. Quote Link to comment Share on other sites More sharing options...
Pancho Posted July 29, 2015 Author Share Posted July 29, 2015 (edited) Thanks! It works, though I guess you can't select an edge loop (e.g. polys) and then use Edge Divide. Selecting all edges parallel to each other needs to be done manually, or? But glad that it works at all. : ) Edited July 29, 2015 by Pancho Quote Link to comment Share on other sites More sharing options...
magneto Posted July 29, 2015 Share Posted July 29, 2015 You can but you have to come up with a way to select those shared edges, then pass it onto Edge Divide. Bear in mind Edge Divide is not perfect either so might have to create your own version of that too, especially if you want to shift, manually specify new loop positions like LightWave's BandSaw tool. Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted July 29, 2015 Share Posted July 29, 2015 (edited) Selecting all edges parallel to each other needs to be done manually, or? You can select paralel edges with 'A' key as well as a consecutive edges. This is universal hotkey for selecting loops and rings. Edited July 29, 2015 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
anim Posted July 29, 2015 Share Posted July 29, 2015 I think magneto meant doing ring loop out of multiple edges at the same time, so like ring loop of an edge loop instead of ring loop of just one edge Quote Link to comment Share on other sites More sharing options...
magneto Posted July 29, 2015 Share Posted July 29, 2015 Yes sorry if it wasn't clear. Basically if you want to use a poly loop, then you need to select the inner edges which are edge rings, and pass it onto Edge Divide. Edge Divide won't necessarily connect the points correctly though if the edge selection is complex. Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted July 31, 2015 Share Posted July 31, 2015 https://youtu.be/ONSYbtf-0Wo Quote Link to comment Share on other sites More sharing options...
