custom pyro pressure
Hi,guys.
Recently, i want built a tornado like pyro, a huge storm.
post-9982-0-32981800-1439702313_thumb.jp
The image come form man of steel,Alexander Lombardi Fx Reel ,https://vimeo.com/84196857
Before it , i have to list a better way to drive smoke rotate.
So there is a simple test which include a tube source and a vortex force, i'm just add the vortex to the vel filed,  after a while, you can see the smoke looks like a dish.post-9982-0-97610700-1439701161_thumb.jp
I don't know if it was a nature shape, most like the air in middle was all been push out, so the air on top and bottom be attract in.
So i have to find a way to disturbance to vel, first i want do it by pressure, high pressure air flow to low pressure lead to a wind, is it right?
So  i inject a custom pressure field, i not clear with how pressure working in pyro, i can export the pressure filed or modify it, but the pyro simulate not change at all, even i set the pressure to 0.
Second way i modify the vel field directly, at the few frame of beginning, the vel field was direct to middle soon, i built a gradient field of the vel.y , if it great a value, then slow down the vel,  it clamp the vel totally, although the smoke not rotate crazy, but it also lose the nature detail.
post-9982-0-34976100-1439703298_thumb.jp
I will keep optimize the second way.
If anyone lead me a better way to built the tornado storm, or explain me how pressure working will be great.
Thanks.
pyro_pressure.hip
