[SOLVED]Single State Crowd Possible?
Atom
Hi All,
I am trying to help out Carlo_C with his crowd problem and I ran into something I could not solve myself. Using his FBX (located here: http://forums.odforce.net/topic/23560-3ds-max-biped-to-crowd-agent/)I have a single biped walking. So I go through the steps of...
1.) Import FBX.
2.) Create Bake Agent (shelf tool)
3.) Bake the agent and yes the files are created.
4.) Populate to generate a crowd_source node (shelf tool).
5.) Simulate to generate the default simulation using the crowd_source. (shelf tool)
This kind of works but the default simulation contains two states, walk and stand. I just want walk.
When I play the simulation my walk starts to happen but then everything starts scooting because I don't have a stand state.
I thought I could just disconnect the unwanted states and transitions but then the solver no longer works. I also thought...well I will just rename the stand to walk for both state and transition but this no longer works either and actually cause Houdini to graphically glitch out and become unusable.
So I guess I'll just ask the question. Can I have a single state crowd system or do I always need two states for the solver to work correctly?
I am attaching my setup HIP file. You can fetch the FBX from Carlo's link mentioned above if you want to try this out.
test_B_Man_01.FBX_SCOOT.zip
Edited by Atom
After watching Peter Quints new Vimeo tutorial on the crowd system I think I have figured it out.
And YES, you can use a single agent with only one state. The problem, of course, was configuring the crowd_source node correctly.
I am attaching the fixed scene along with the baked out agent folder.
test_B_MAn_01.FBX_FIXED.zip
Edited by Atom
Atom thanks so much for your help, after watching the Peter Quint video and looking at your file it all made sense and I was able to get it working! From your example it looks like the sticking point was a combination of the FBX import and getting the agent to bake out properly. Changing the FBX import setting fixed the error I was getting. Also knowing what to configure on the crowdsource node!
Time to save out some more states for this test guy and see if I can get a crowd sim working in a simple production scene. Once again thanks for the help Atom it's massively appreciated!! :)
