Ray SOP ignore backfaces
Rikrok
you probably can't do that in Ray SOP
but you can use intersect_all() VEX function or VOP to get all intersections along the line, then check in for loop for first one that is not back facing
Edited by anim
  • 4 years later...
if you want your ray to continue through all backfaces and hit something behind you'd need to do something along the lines suggested in previous posts
vector t = chv("t");
vector dir = normalize(chv("dir"));
float maxlength = chf("maxlength");
// get all intersection
int prims[];
vector hitPs[], primuvs[];
intersect_all(1, t, dir*maxlength, hitPs, prims, primuvs, .001, .001);
// filter out backface intersections and stop at first frontface
vector outP = t + dir*maxlength;
foreach(int i; vector hitP; hitPs){
    int prim = prims[i];
    vector primuv = primuvs[i];
    vector hitN = primuv(1, "N", prim, primuv);
    float dot = dot(dir, hitN);
    if (dot < 0){
        outP = hitP;
        break;
// create line
int pt0 = addpoint(0, t);
int pt1 = addpoint(0, outP);
addprim(0, "polyline", pt0, pt1);
ts_intersect_ignore_backfaces.hip
Edited by anim
  • Like 2
  • 5 years later...
hi! i came across a similar issue i'm trying to solve, i'm still learning houdini and wondering if the vex is a 'replacement' for the ray node or is it something that it checks after the ray node? does the intersection mean the intersection with the ray-ed points and the geometry?
thanks in advance!
