Alexey Vanzhula Posted December 1, 2015 Share Posted December 1, 2015 (edited) Is hscript deprecated? Or not? Edited December 1, 2015 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
graham Posted December 1, 2015 Share Posted December 1, 2015 Unless SESI has secretly released something newer that replaces it, I would say 'No'. Quote Link to comment Share on other sites More sharing options...
jrockstad Posted December 1, 2015 Share Posted December 1, 2015 They are really pushing for people to be using Python these days, but I'm not sure if that counts as HScript being officially 'deprecated.' Here are some relevant quotes from the Houdini documentation that I've run into: The Houdini Object Model (HOM) is an application programming interface (API) that lets you get information from and control Houdini using the Python scripting language. HOM replaces the functionality of Houdini’s previous scripting solutions, the expression language and HScript. HScript is the Houdini’s old scripting language. HScript is still available in Houdini for compatibility with older files and scripts. For new scripts, we recommend you use the scripting APIinstead. I think HScript will probably be supported for a while yet, largely because most people still seem to be using the HScript-based expressions, but if you're doing any kind of serious scripting Python is definitely the way to go. Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted December 1, 2015 Author Share Posted December 1, 2015 No, I don't want SESI to remove hscript expressions. No. It still very useful and faster than python in simple cases.But I don't like python-hscript fusion in shelf tools (when you drop nodes island to shelf) for example. And why scene file (HIP) still not a Python script? I don't understand. Quote Link to comment Share on other sites More sharing options...
lisux Posted December 1, 2015 Share Posted December 1, 2015 NOPE Hscript is still very deep into Houdini. SESI advice to use Python rather than Hscript , but at the moment, Hscript is faster more reliable and in some cases has functions that doesn't exists in hom. Also callbacks implemented with Python don't scale well. For all of these I still prefer to use Hscrit for expressions. Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted December 1, 2015 Author Share Posted December 1, 2015 For all of these I still prefer to use Hscrit for expressions. I only use hscript expressions Also callbacks implemented with Python don't scale well What callbacks do you mean? Quote Link to comment Share on other sites More sharing options...
jrockstad Posted December 2, 2015 Share Posted December 2, 2015 Yep, it's easy to see why most people still prefer the old-style expressions. Consider the ubiquitous $PT expression vs. the Python equivalent: pwd().curPoint().number() Now which one of those is easier to remember? Quote Link to comment Share on other sites More sharing options...
lisux Posted December 3, 2015 Share Posted December 3, 2015 What callbacks do you mean? Parameters callbacks Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted December 3, 2015 Author Share Posted December 3, 2015 Parameters callbacks What problems do you have with python parm callbacks? Quote Link to comment Share on other sites More sharing options...
Pavel Posted January 2, 2016 Share Posted January 2, 2016 I don't know about python but in my experience VEX seems to be replacing Hscript. The cooking times are much faster in VEX and in many ocasions it's easier than attribute VOP to setup something. I am pushing myself to learn VEX as much as possible. Quote Link to comment Share on other sites More sharing options...
edward Posted January 3, 2016 Share Posted January 3, 2016 HScript expressions: For simple one liners on parameters HScript commands: Deprecated in favour of Python where possible Python: For scripting (when you need loops and functions, or more) VEX/VOP: Large data processing 2 Quote Link to comment Share on other sites More sharing options...
