simplest wrangle question
Follyx
ok, I have a pointwrangle and afterward an attribvop with an promoted offset vector.
Code in the pointwrangle is v@skn = .{2,0,0};
If I use it in the promoted offsetvector like @skn.x,0,@skn.z
nothing will happen. So whats wrong with it.
Ok and the second:
If I want to write the @skn wiht $F for x, how should be the syntax for it: @skn = {$F,0,0}?
(ok I know $F its wrong but whats it for vex? @F?)
Thanks in advance
One thing to remember about  {x,x,x} is that it only accepts constants. You can only use it for that. (i.e. @skn  = {0,1,2}; no variables are allowed) To use variables you use the set key word. So @skn = set(x,y,z); will work. As far as $F you can back tick insert it directly like so @skn = set(`$F`,0,0); or use @Time @skn = set(@Time,0,0);
Edited by Atom
