chrisdunham95 Posted January 26, 2016 Share Posted January 26, 2016 Hey guys - working on a hand made of snow crumbling affect got exactly what i want and know how to control it as i please except i dont know how to go about making it crumble from the finger tips then downwards as such - in Maya i guess id use a ramp or texture of some form - Quick rendered version of the hip file attatched any help would be great! - even if its an explanation or link to tutorial or just fixed hipfile Thanks guys C (Cache is huge and thus havent added it too) HandDestructionSnow1.hipFetching info... Quote Link to comment Share on other sites More sharing options...
chrisdunham95 Posted January 26, 2016 Author Share Posted January 26, 2016 - For example im using max speed/accel to keep it still for a few frames (if i could connect these paramteres to a sphere and whatever is outside of the sphere is moving and inside frozen and slowly animate the sphere moving down the arm and thus crumbling - Have no idea how i would do this in Houdini however! Quote Link to comment Share on other sites More sharing options...
Atom Posted January 26, 2016 Share Posted January 26, 2016 I just watched Ben Watts tutorial on growth propagation. You might be able to use the technique to drive what ever is holding your snow together to make it collapse over time. 1 Quote Link to comment Share on other sites More sharing options...
chrisdunham95 Posted January 26, 2016 Author Share Posted January 26, 2016 Thanks alot Atom saw this a while back i think you maybe right! Quote Link to comment Share on other sites More sharing options...
ispep Posted January 28, 2016 Share Posted January 28, 2016 Don't want to send you off in the wrong direction but; digital tutors has a tutorial on a statue that crumbles over time from the top downwards and the destructible area (if I remember) is determined by an animated collider (a sphere). It floats over the glue constraint network or something like that. It might be worth a look. 1 Quote Link to comment Share on other sites More sharing options...
stevegh Posted January 28, 2016 Share Posted January 28, 2016 You can also use the "stopped" attribute. Check the attached file. grains_activateInChunks_sh.001.hipFetching info... 1 Quote Link to comment Share on other sites More sharing options...
chrisdunham95 Posted January 30, 2016 Author Share Posted January 30, 2016 Thanks Guys will check out both your ideas really appreciated Quote Link to comment Share on other sites More sharing options...
