cudarsjanis Posted March 2, 2016 Share Posted March 2, 2016 My first VFX shot. If I would have known how hard and time consuming it`s going to be, I would have chosen something more simple for the first project. But I learned a lot by making this shot. Hope you like it. Janis Quote Link to comment Share on other sites More sharing options...
reelinspirations Posted March 2, 2016 Share Posted March 2, 2016 I think it looks great. I'm just learning Houdini and that's pretty cool for your first project. Quote Link to comment Share on other sites More sharing options...
davpe Posted March 2, 2016 Share Posted March 2, 2016 for the first work, I think it's awesome. good work. keep it up! Quote Link to comment Share on other sites More sharing options...
jon3de Posted March 3, 2016 Share Posted March 3, 2016 Hi, Well done, Could you tell us some things about the workflow you did use for that? For me I still stick to SOPs and didnt´t get in contact a lot with DOPs but I´m curious though. I saw in the Breakdowns that there is some (maybe displacement) layer on top of the fluid sim but only on the outer part of the simulated mesh. Is that right? I´m asking you because recently I asked myself about how the workflow would look like if I want to blend my simulated mesh of a small part of an ocean with the rest of a non simulated ocean. At least I think that the extended Ocean in the background of your shot is a non simulated mesh? But it blends nicely with the simulated water. Did you blend this in compositing? kind regards Jon Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted March 3, 2016 Author Share Posted March 3, 2016 (edited) Hi, Well done, Could you tell us some things about the workflow you did use for that? For me I still stick to SOPs and didnt´t get in contact a lot with DOPs but I´m curious though. I saw in the Breakdowns that there is some (maybe displacement) layer on top of the fluid sim but only on the outer part of the simulated mesh. Is that right? I´m asking you because recently I asked myself about how the workflow would look like if I want to blend my simulated mesh of a small part of an ocean with the rest of a non simulated ocean. At least I think that the extended Ocean in the background of your shot is a non simulated mesh? But it blends nicely with the simulated water. Did you blend this in compositing? kind regards Jon I did a bit of both. ocean behind is just ocean displacement applied to a grid. As this was my first project, I probably am using some wrong techniques. I think the best way to achieve this is to group particles either by bounding object or velocity. and then you can merge particles that make that splash with particles with ocean displacement applied, and only then run VDB from particle fluid, and mesh them. Here I set up quick project how I think this is working. Of course waves are not so rough as they would be if you applied displacement straight to the mesh. but you can blend both in comp. As I said, I`m quite new to houdini so I`m not saying this is the right way to do it! This is just something I came up with, combining some advises from oforce users and some tutorials. I could upload the project file If knew how to add files, when commenting. Somehow I see that only when I`m starting new topic. Edited March 3, 2016 by cudarsjanis Quote Link to comment Share on other sites More sharing options...
jon3de Posted March 3, 2016 Share Posted March 3, 2016 Thanks. If you want to upload a file just use "More Reply Options" next to the "Post" button. Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted March 3, 2016 Author Share Posted March 3, 2016 Thanks, will know how to add files next time. Added the project file, if you want to have a look. Mesh.hipnc 1 Quote Link to comment Share on other sites More sharing options...
