BURNING VEHICLES
Sankar Kumar
Looks good, my only comment would be not to use flames on the rubber tires. I don't know if you have ever tried to set a tire on fire in real life, but it is not that easy. Rubber tires also put out a different kind of smoke, much more thick.
Thank you Atom, For now I updated the shader little bit on the same mid resolution simulation. I am preparing the bus details and environment. I will check tire burning videos and include in the Final simulation.
