Understanding VEX command in docs
Arthur Spooner
I'm going though some VEX function commands to understand, and I'm having a little difficulty understanding for example addprim. What I have thus far,
v@gm = addprim();
The docs state int, is this a hard and fast rule if the docs state an integer I shouldn't be making a vector variable, rather a integer variable ?
Adds a primitive to the geometry.
  • int addprim(int geohandle, string type)
Creates a primitive in the geometry specified by geohandle. The returned value is a primitive number that can be used with the setprimattrib to change the value of the primitive, but is not the final primitive number of the primitive.
Types can be:
poly: Closed polygon.
polyline: Open polygon.
Another command is neighbors, which returns an array of the point numbers of the neighbors of a point. Once again the docs state, integer with an empty array followed by int input, int ptnum, what must I enter for those values ? Must I select a point on the mesh ?
That must be a typo, it should be int like you wrote:
i@gm = addprim(...)
You could use a vector as all the components of the vector wuold be set to the same value when using: v@gm = addprim(...) but it would just get messy unless you need it for som especial case.
This is how you declare an array attribute:
i[]@mypoints = neighbours(0, @ptnum);
If you want to declare a variable, go like this:
int mypoints[] = neighbours(0, @ptnum);
The example code in the docs: http://www.sidefx.com/docs/houdini15.0/vex/functions/neighbours is not correct:
To work it needs to look something like this:
int input = 0; //Just passing in some values for testing. 0 is the first input of the Wrangle node.
int ptnum = 20; //Just passing in some values for testing
int myarray[] = neighbours(input, ptnum);
int i, n;
int result[];
n = neighbourcount(input, ptnum);
resize(result, n);
for (i = 0; i < n; i++) {
    result[i] = neighbour(input, ptnum, i);
i[]@test = myarray; // Set Geo Spreadsheet to Detail to see the members of the array
Put down a Grid and an Attribute Wrangle set to Detail to test. Change "ptnum" to set a different point.
Hope this answers your questions.
Cheers
Bonsak
Edited by bonsak
i@gm = addprim(...)
int i, n;
int result[];
resize(result, n);
Cheers
Bonsak
i@gm = addprim(...)
How do I use addprim ? The docs state it createa a primitive in the geometry specified by geohandle ?
The above code is starting from the first point then giving each point an id followed by storing that in an array called @mypoints ?
Edited by Arthur Spooner
Very basic example would be like this:
int prim = addprim(geoself(), "poly");
int pt1 = addpoint(geoself(), {0,0,0});
int pt2 = addpoint(geoself(), {0,0,1});
int pt3 = addpoint(geoself(), {1,0,1});
int pt4 = addpoint(geoself(), {1,0,0});
int vt1 = addvertex(geoself(), prim, pt1); // Actually no need to set the int like this, just old habbit.
int vt2 = addvertex(geoself(), prim, pt2);
int vt3 = addvertex(geoself(), prim, pt3);
addvertex(geoself(), prim, pt4); // This works as well
Put down a null inside a Geo and then attach a Attribute Wrangle set to Detail to see how it works.
No it's returning the neighbouring points around the point you supply in @ptnum from the geo from input 1.
-b
Edited by bonsak
I created a torus, connected a null, followed by a point wrangler, inserted the code, got a plane, sounds correct ?
How do I know what to make a int, v etc in Houdini ?
Breaking this line of code down; int prim = addprim(geoself(), "poly");
How did you know to make prim a integer ? I'm reading over and over in the docs for Prim & addPrim & Geoself and I'm not understanding, arghhh. :angry:
Adding the null is only for when you want to start creating geometry from scratch. Attribute Wrangle needs an input of some sort to not error out.
What is cd used for the example; prim ?
I don't understand.
The string "poly" that we're passing to addprim() is only describing the type of poly you want to make: "poly" (closed) or "polyline" (open)
-b
I don't understand.
-b
What is the attribute Cd ? That is what I should've asked !
You don't add attributes to geoself(). geoself is just a function that returns a handle to the geometry being processed.
If you want to set attributes to geometry for example, try a Point Wrangle for instance. To set the color of the points you go:
@Cd = {1,0,0};
-b
@Cd = {1,0,0};
-b
The geometry, whether it be a sphere, or cube etc should've turned red ?
and if you're in the detail mode, you can set a point attribute like this:
setpointattrib(geoself(), "Cd", ptNum, {1,0,0})
You mean detail mode in Geo Spreadsheet ? :unsure:
What is meant by "it returns a handle" to the geometry being processed, sorry it's the terms ! :)
int prim is not a variable, rather the command which must be used.
One imports the attribute value from geometry, in this case, it is importing an empty geohandle, then points are being creating, to create a closed polygon ?
0,0,0 > no points
0,0,1 > point at world z ?
1,0,1 > point at world, x & z ?
1,0,0 > point at world, x ?
that's normal, you gotta provide it with a point number ;)
something like that
int npts = npoints(0);
for(int i = 0; i<npts;i++){
    setpointattrib(geoself(), "Cd", i, {1,0,0})
but I would recommend to do as much as possible in point/prim/vertex mode instead of in the detail mode as that last one isn't multithreaded.
