aracid Posted February 21, 2005 Share Posted February 21, 2005 hey all just a little question about keying points, i would think through the edit sop. how can u manually animate the points or faces of nurbs or polys? thanks in advance aracid Quote Link to comment Share on other sites More sharing options...
deecue Posted February 21, 2005 Share Posted February 21, 2005 transform sop soft transform sop peak sop soft peak sop point sop Quote Link to comment Share on other sites More sharing options...
edward Posted February 22, 2005 Share Posted February 22, 2005 add sop Quote Link to comment Share on other sites More sharing options...
deecue Posted February 22, 2005 Share Posted February 22, 2005 add sop 16442[/snapback] ahh, well played. Quote Link to comment Share on other sites More sharing options...
aracid Posted February 22, 2005 Author Share Posted February 22, 2005 hey all thanks for the reply's but maybe i wasnt clear enough about what i wanted to do, basically what u would achieve with a blend shape sop, moving between different poses. in maya u move into component mode and select ur vertex or point add a key etc. i would think that u can just key the edit sop, but i havent had any luck with that. thanks again aracid Quote Link to comment Share on other sites More sharing options...
Jason Posted February 22, 2005 Share Posted February 22, 2005 I'm afraid unless you are (crazy enough to be) keying Transform SOPs, the accepted paradigm is to you edit up your target shapes and BlendShapeSOP them together. It seems a little more awkward but you'll find that the blending will be much easier to control just by animating weight shapes rather than trying to handle hundreds of channels representing the animation on each point of a surface. Hope this helps a little, Jason Quote Link to comment Share on other sites More sharing options...
aracid Posted February 22, 2005 Author Share Posted February 22, 2005 I'm afraid unless you are (crazy enough to be) keying Transform SOPs, the .....Hope this helps a little, Jason 16449[/snapback] hey jason thanks for the tip thats pretty much what ive been doing, and it works well, but i just wanted to make sure that there wasnt another solution thanks to all the previous posters again aracid Quote Link to comment Share on other sites More sharing options...
edward Posted February 23, 2005 Share Posted February 23, 2005 Aw come on, that's no fun! Use an add sop to create all your geometry and then animate the point positions there! In H7.0, there's the new Morph tool that should help a bit should you cowardly decide on the blendshape route. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted February 23, 2005 Share Posted February 23, 2005 Bring the points into chops and use the graph editing tools there, then export the result back to sops! Quote Link to comment Share on other sites More sharing options...
FrankFirsching Posted February 28, 2005 Share Posted February 28, 2005 Real men use the Unix-SOP and write a shell script Quote Link to comment Share on other sites More sharing options...
