ConvertVDB- no density channel
Hi guys,
i am struggling with stupid problem, i want to convert my bgeo files to VDB to later render them with arnold. But on convertvdb node i have that density channel is <empty>. I don't know what is wrong with my scene, for test i created same setup flames from the shelf, didn't change anything and it's working.
Do you guys have any suggestion?
Thanks
firenosmoke_v003.hip
Well, if it is working in your test scene, most certainly there is a glitch in your original scene. go through all your nodes and check how the data is changing. But without seeing that original scene of yours it is almost impossible to tell you want went wrong.
