Kardonn Posted May 5, 2016 Share Posted May 5, 2016 Anyone able to point me in the right direction with how to set up a Multi Solver that would let a wire sim be blown around by a pyro sim? Just messing around for fun with simming some long hair, thought it would be neat to have it interact with an actual simulated wind instead of just some kind of curl noise force...then realized I have no idea how and searching the net wasn't too helpful for it either. Quote Link to comment Share on other sites More sharing options...
narbuckl Posted May 5, 2016 Share Posted May 5, 2016 several ways to do it. If you want a lot of control I would just use a wrangle node in a sop solver, point to your velocity sim say with input 1 so the code would be: vector vel = volumesamplev(@OpInput1,"vel",@P); @v += vel; then you can mult or do whatever do the velocity vector before its added to your wires velocity value. Could also combine popsolver and use advect by volume, but I figured this was simpler. -N Quote Link to comment Share on other sites More sharing options...
Kardonn Posted May 5, 2016 Author Share Posted May 5, 2016 Yeah that makes a lot of sense, but only issue is just that I'm back to not knowing how you actually combine the SOP Solver together with the Wire Solver in the same DOP Network. Right now (and I'm sure this is wrong) I have the Wire Solver feeding into the Multi Solver's left input, the SOP Solver into the right input, if I go into the SOP Solver I can see my wires and interact with them...but if I do something like "@v += {1,0,0};" I just watch the vel vectors grow in the viewport without anything actually happening. Quote Link to comment Share on other sites More sharing options...
Kardonn Posted May 5, 2016 Author Share Posted May 5, 2016 (edited) Oh this is much MUCH easier than I was imagining... Under the Drag tab in the Wire Object, you've got Normal Drag and Tangent Drag, and External Velocity Field (defaulted to "vel"). As long as you merge the Wire Solver with a Pyro/Smoke Solver, it will affect it already by default! Another problem solved by the old "read the ****ing manual" addage. I was just reading the wrong manual for the Wire Solver instead of the Wire Object itself where this magic happens. Edited May 5, 2016 by Kardonn 1 Quote Link to comment Share on other sites More sharing options...
narbuckl Posted May 5, 2016 Share Posted May 5, 2016 35 minutes ago, Kardonn said: Oh this is much MUCH easier than I was imagining... Under the Drag tab in the Wire Object, you've got Normal Drag and Tangent Drag, and External Velocity Field (defaulted to "vel"). As long as you merge the Wire Solver with a Pyro/Smoke Solver, it will affect it already by default! Another problem solved by the old "read the ****ing manual" addage. I was just reading the wrong manual for the Wire Solver instead of the Wire Object itself where this magic happens. haha goodtimes! If you wanted to break it out into 2 steps so you could do your fluid sim separately you were on the right track. Multi-solver, then wire object goes into the far left connector then the wire solver goes into the right connector followed by the sop solver. treat the right connector like a merge, with a left to right hierarchy where you are just combining the solvers . The main solver being the first one plugged into the right input, nothing needs to be plugged into either of those solvers. -N 1 Quote Link to comment Share on other sites More sharing options...
Kardonn Posted May 5, 2016 Author Share Posted May 5, 2016 Thank you, that's a big help! I finally get how to use the Multi Solver. 1 Quote Link to comment Share on other sites More sharing options...
narbuckl Posted May 5, 2016 Share Posted May 5, 2016 Just now, Kardonn said: Thank you, that's a big help! I finally get how to use the Multi Solver. Now combine all the things! Quote Link to comment Share on other sites More sharing options...
Kardonn Posted May 12, 2016 Author Share Posted May 12, 2016 Here if anyone was curious to see some results, it's a pretty nice look for simulating long hairs. https://www.dropbox.com/s/j8szbynrcxj0ycn/hair_advection2.mov?dl=0 Quote Link to comment Share on other sites More sharing options...
6ril Posted May 12, 2016 Share Posted May 12, 2016 looking good ! congrats, pretty natural feeling to it. Quote Link to comment Share on other sites More sharing options...
michael Posted May 12, 2016 Share Posted May 12, 2016 Quote Link to comment Share on other sites More sharing options...
tious13 Posted May 14, 2016 Share Posted May 14, 2016 (edited) Hi, nice effect ! I tried something according to what you said but I can't get any advection. Is there something that I miss? [edit] my bad : "react to fluids and smoke when the Tangent Drag and the Normal Drag have been chosen sufficiently large" read the doc... Edited May 14, 2016 by tious13 Quote Link to comment Share on other sites More sharing options...
