Gtx 1080 OpenCL performance
Guest tar
Nice! that looks good, though I'm a touch hesitant as the last AMD board is currently being dissected as simming killed it. Maybe the Sapphire fan and heatsink wasn't up to scratch or OsX thermal management is junk.
There's also a rumoured TitanX based on a GP102 GPU, with more 50% more ALUs (3840). Still speculated to have 1/32 FP64 based on die size, though (not that it matters for Houdini).
http://techreport.com/news/30174/rumor-a-gp102-geforce-titan-and-gtx-1080-ti-are-in-the-works
If the 24GB VRAM of GDDR5X is accurate, it's not going to be cheap - probably quite a bit more than the previous Titan.
Nice, that should perform better!  On the memory side; I've the gpu memory monitor open and Houdini, OpenGLROP, a 4K and 2k screen almost gobbles all the 980's 4GB memory up pretty quickly!  8GB might be enough but maybe more is better especially with OpenCL tasks.
Out of interest does anyone have experience with these founders/reference designs fan and thermal unit, like on the Gtx 1080? The 980 evga is super quite, in comparision with the Amd 7950, and, it had a similar looking thermal design as the 1080.
Edited by tar
Add Houdini memory usage on 980
You're meant to be able to launch two Houdinis that can then each use a graphics card for OpenCL, but sharing the workload isn't happening yet. H16 maybe, and it should happen at one point in the future, via TBB or a later version of OpenCL.    Octane can use multiple cards, which makes rendering a piece of cake.
