Guest tar Posted June 25, 2016 Share Posted June 25, 2016 (edited) Is anyone else seeing errors rendering with Arnold in Indie? 00:00:00 437MB ERROR | [ass] writing scene files is disabled **** * Arnold 4.2.14.0 darwin clang-3.8.0 oiio-1.5.24 rlm-12.0.2 2016/06/13 16:32:41 * CRASHED in at 00:00:00 * signal caught: SIGSEGV -- Invalid memory reference * * backtrace: * 0 0x0000000122f61c95 [libai.dylib] AiShaderGlobalsEdgeLength * * loaded modules: * 0x0000000122d30000 libai.dylib htoa-1.12.0_r1769_houdini-15.5.480 H15.5.480, OsX 10.10.5 Edited July 16, 2016 by tar Quote Link to comment Share on other sites More sharing options...
RayFoundry Posted June 28, 2016 Share Posted June 28, 2016 I'm having the same issue. HtoA - Error whilöe writing ASS file (-1) Quote Link to comment Share on other sites More sharing options...
cgcris Posted June 28, 2016 Share Posted June 28, 2016 Are you trying to export ass files? This is a limitation of indie, for all renders. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted June 28, 2016 Share Posted June 28, 2016 2 hours ago, cgcris said: Are you trying to export ass files? This is a limitation of indie, for all renders. Did you try it? That's the error that's generated when you click render for IPR or Mplay. Then the render doesn't work and errors out. Quote Link to comment Share on other sites More sharing options...
RayFoundry Posted June 28, 2016 Share Posted June 28, 2016 (edited) No, I'm just adding the Arnold ROP, setting the correct links to the cam and rendertarget (which i'm using the provided Digital Asset for) and press render. (Edit: Also using the Arnold Standard Material on a sphere geo). As far as I'm aware, the ASS export tab is hidden anyway from the ROP otl by detecting the Houdini version. There's a python expression checking for houdini or houdini educational. Edited June 28, 2016 by RayFoundry Quote Link to comment Share on other sites More sharing options...
Toledor Posted July 1, 2016 Share Posted July 1, 2016 Same issue happening here. I made a simple sphere, arnold light, arnold standard and arnold rop and when I try to render the "Error: [htoa] Error while writing ASS file" appears again and again. I contacted SESI, if I get an answer I'll let you know. Cheers Quote Link to comment Share on other sites More sharing options...
Cybernetix Posted July 1, 2016 Share Posted July 1, 2016 i have the same error, sorry dont have a solution, just posting to follow the thread.. Quote Link to comment Share on other sites More sharing options...
kikou Posted July 8, 2016 Share Posted July 8, 2016 Hi all, This is an HtoA bug that affects OSX only, logged as ticket #808. It's been fixed in the trunk and should be out soon in an upcoming bugfix release. Sorry about the inconvenience. Quote Link to comment Share on other sites More sharing options...
whtnoise Posted July 8, 2016 Share Posted July 8, 2016 I'm actually having this same issue with Windows 10... Quote Link to comment Share on other sites More sharing options...
Guest tar Posted July 16, 2016 Share Posted July 16, 2016 All fixed on OsX with htoa 1.1.2.1. Thanks! Fwiw. If you have trouble launching the installer, use RMB 'Show Package Contents' then run 'Contents/MacOS/htoa-1.12.1_r1781_houdini-15.5.523_darwin.run' from a terminal. Quote Link to comment Share on other sites More sharing options...
