Adding temperature to VDB volume
logix1390
Hello,
So I have been diving deeper into VDB and I came across a small issue. When I add temperature to the VDB volume it gives me very weird results in the dopnet. When I visualize the temperature, it seems as if it is only appearing on the x axis. Any thoughts on this issue ? I attached my file. Thank you
vdb_temperature_problem.hip
