art3mis Posted July 29, 2016 Share Posted July 29, 2016 (edited) Some confusion. Browsing the documentation there is reference to Command Line Tools. This doesn't exist in Houdini 15.5 AFAIK. http://www.sidefx.com/docs/houdini15.5/basics/config_env I've tried making 2 changes to my environment variables 1 added a new variable called houdini_setup with a value of C:\Program Files\Side Effects Software\Houdini 15.5.528 2 added a new Path variable with a value of C:\Program Files\Side Effects Software\Houdini 15.5.528\bin I'm running Indie in Windows 10. Can anyone point me to an up to date, step by step guide for properly configuring the Houdini environment in Windows 10? Also some confusion re command line vs Powershell in Windows 10. To launch and run Houdini, are they interchangeable or? Edited July 29, 2016 by eco_bach Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted July 29, 2016 Share Posted July 29, 2016 (edited) Install Windows 10, install Houdini. There's a shortcut in the Start menu for the command line tools. It's calling "C:\Program Files\Side Effects Software\Houdini 15.5.523\bin\hcmd.exe" when you click the command line tools shortcut. If you're new to Windows 10 you might want to set updates to schedule otherwise it'll just randomly restart while you're working - super annoying. Edited July 29, 2016 by lukeiamyourfather 1 Quote Link to comment Share on other sites More sharing options...
