Vector pass of VDB Volume
I have a whitewater simulation which I converted to a vdb volume. Is it possible to render a vector pass out of this vdb ? I want to blur my whitewater pass in Nuke as I don´t get proper motion Blur while rendering it in mantra.
I tried it with import the velocity to an image plane but this works only for normal geometry. With vdb volumes I did not had luck for now. I would be thankful for some ideas.
Jon
Ah right. I scaled the values a little bit now I can see the effect. Thank you very much David.
Anyway do you know how its possible to render out a 2d Vector pass to blur it in comp ? Or is this generally not a good idea to blur volumes in comp?
