art3mis Posted August 3, 2016 Share Posted August 3, 2016 As a novice wondering if there was a reason to choose the old PopNet instead of the new one. Can anyone summarize the advantages of one vs the other? From a learning perspective the old PopNet seems much more intuitive and easier to work with. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted August 3, 2016 Share Posted August 3, 2016 The new POP network is built on top of the DOP network which is multithreaded. The old POP network isn't. If you're doing fairly simple things then it doesn't matter which one you do it in. If you're doing very complex or very large simulations then the payoff for using the new POP network is huge. Quote Link to comment Share on other sites More sharing options...
art3mis Posted August 3, 2016 Author Share Posted August 3, 2016 thanks! Quote Link to comment Share on other sites More sharing options...
gaurav Posted August 3, 2016 Share Posted August 3, 2016 Some correct me if i am wrong. They are also much more Memory Efficient, earlier pops were linked lists in memory. Quote Link to comment Share on other sites More sharing options...
benne5 Posted August 3, 2016 Share Posted August 3, 2016 The new pops workflow is also synonymous with the increased use of VEX and wrangle node workflows. If you were used to the old school pops method it can take some getting used to. Given the efficiencies already mentioned in this thread, partnered with the strength of VEX, the new pops system is quite dynamic! (No pun intended) Quote Link to comment Share on other sites More sharing options...
