Attribute Interpolate?
I just had a look at your scene. You need to have the attributes you want to interpolate filled out on the node in the 'Point Attributes' parameter. It defaults to * but your nodes have nothing in there, you will at least need to have P for it to move the points.
Excellent!  Just needed to add "P" to the point attribute on the Interpolate node.
