squardis Posted August 13, 2016 Share Posted August 13, 2016 Hi, Im trying to let a fluid drive my rbd/bullet object but it just doesnt work. Never did this before. Does anyone have a quick example? tried multisolver, merge Left input to advect right, ... Just a simple smoke shelf and object would be enough as a example. Like particle advect, but with geometry. THNX alot Quote Link to comment Share on other sites More sharing options...
zaken7 Posted August 14, 2016 Share Posted August 14, 2016 (edited) Hey squardis, This topic may help you http://forums.odforce.net/topic/21991-flip-with-bullet-interaction/ I did something similar and I didnt remenber using the multisolver. Usually the feedback scale should do the trick. Edited August 14, 2016 by zaken7 Quote Link to comment Share on other sites More sharing options...
Federico Posted August 14, 2016 Share Posted August 14, 2016 I don't know if i understood your request right, but if so i believe i did something similiar. I wanted to have an object driven by the fluid sim (in my case a beach ball floating on the water) but i had already simulated and meshed the water. So i used the FEM system for the beach ball and the mesh water was the collider. Quote Link to comment Share on other sites More sharing options...
squardis Posted August 14, 2016 Author Share Posted August 14, 2016 well, I meant to drive a fractured geo by a explosion fluid (No gravity) I can send you the file but for test purposes 1. -> sphere .... -> explosion shelf 2. fracture a object and let it move by the fluids @zaken7 I will look at it right away thnx Quote Link to comment Share on other sites More sharing options...
Farmfield Posted August 15, 2016 Share Posted August 15, 2016 Packed prims are particles, so you can use POP forces directly into the Rigid Body Solver as it has a multi solver inside. rbd_advect.hiplc 3 Quote Link to comment Share on other sites More sharing options...
squardis Posted September 14, 2016 Author Share Posted September 14, 2016 THnx!!! thats exactly where I was Looking For Quote Link to comment Share on other sites More sharing options...
