Command line and batch rendering with Redshift
So my understanding is you can use command line tools to render out a frame or frame range like so
hrender -e -f 4 39 -v -d your_ROP path_to_file/with_no_spaces_in_name.hip
and also a batch file after creating your batch file first.
What changes would you need to make if you are using a GPU renderer like Redshift or Octane?
