ISUther Posted September 2, 2016 Share Posted September 2, 2016 Hello, I have a problem with Houdini FX If you take a look at this video tutorial:http://cgterminal.com/2016/01/27/houdini-after-effects-liquid-spider-effect-tutorial/ There if you move to time 02:50 he cre4ates Line (named as "line1" in video) and he changes Lenght to 7 and Points to 25 I did the same thing but i do not get and see the points that he created. (Points on the line) Do you know what is wrong with my setup? Added also project file. Spider.Project.hip Quote Link to comment Share on other sites More sharing options...
Sepu Posted September 3, 2016 Share Posted September 3, 2016 (edited) you need to display the points?? .... that is why you aren't seeing the points I guess that is what you are asking Edited September 3, 2016 by Sepu Quote Link to comment Share on other sites More sharing options...
Farmfield Posted September 3, 2016 Share Posted September 3, 2016 LOL, you can see the points just fine in the first screenshot, they're right there. I'm so confused, I fear I'm being trolled. Quote Link to comment Share on other sites More sharing options...
ISUther Posted September 3, 2016 Author Share Posted September 3, 2016 Yes now i see, thnx i had it turned off and i did not try to troll Quote Link to comment Share on other sites More sharing options...
Farmfield Posted September 3, 2016 Share Posted September 3, 2016 xD Then you've updated the image, right? Because in the image, I can see the points. They are right there. Quote Link to comment Share on other sites More sharing options...
ISUther Posted September 4, 2016 Author Share Posted September 4, 2016 In the image i wanted to show about what points i was talking about Atm i got the tutorial finished. Made my own adjustments and now working with shaders and lights. I really am impressed by houdini and what beautiful stuff you can do here. Day by day learning more. Quote Link to comment Share on other sites More sharing options...
Farmfield Posted September 4, 2016 Share Posted September 4, 2016 Well, either way, cool you got it solved. And yeah, Houdini is pretty amazing. Quote Link to comment Share on other sites More sharing options...
ISUther Posted September 4, 2016 Author Share Posted September 4, 2016 Currently rendering but this is what i have atm. I realy like it. And every time dooing some one else tutorial i learn more and understand more nodes. And may be one day i am able to do some cool animation myself. Quote Link to comment Share on other sites More sharing options...
ISUther Posted September 4, 2016 Author Share Posted September 4, 2016 Hello, It is me again I have fiew questions regarding this project / tutorial. I added my project file here. I am using Ocean surface because i get interesting effect when i use light in scene First question: How to mage effect to grow from 0 to x number. For example: At start of frame there is sphere only and then it sarts to get to get those wiery things more and more and they get frame by frame bigger. Second question: As you see i use there geolight, and this is because i like the effect that i get from interaction light + ocean surface and i created copy of main object and then reduced it size in scale a bit and turned that in to Geometry light that will give me a bit red in the main object And here is a question. How to change that golor to something else then red. Hint! 1.) Select first object and create copy of that 2.) Reduce the copy object size a bit in scale 3.) Turn copy object in to Geometry light Now what you end up is having same object with same animation but as light inside of main object. And my issue here is that no mater where i change the light color it remains RED but i want it to turn some other color. How to do that? Spider.Project.Molekul.hip Quote Link to comment Share on other sites More sharing options...
