lyansart Posted September 4, 2016 Share Posted September 4, 2016 (edited) Hi! I'm pretty new in Houdini, but I have to improve very quickly in 1 and a half month so i'm watching the basic tutorials in the sideFX site. Following a lesson about digital assets I had to create different rocks and try to put them in a curve. But after uploading one single rock and trying to change the expression in $Hip/geo/rock_`padzero(3, ("../copy1", rockNum, 1))`.bgeo it gives me this two errors Unable to read file ".../.../geo/rock_001.bgeo" Unable to evaluate expression (Bad data type for function or operation (/obj/sphere_object1/file1/file)). why is that? i'm pretty sure this is a simple question but without having any professor I don't know who to ask. thank you! Edited September 4, 2016 by lyansart Quote Link to comment Share on other sites More sharing options...
f1480187 Posted September 4, 2016 Share Posted September 4, 2016 There is some strange looking construct used as the second argument of padzero function. From it appearance, it looks like a typical stamp function call, but without the stamp function name. Maybe someone cut it instead of copying. Try this: padzero(3, stamp("../copy1", rockNum, 1)) 1 Quote Link to comment Share on other sites More sharing options...
lyansart Posted September 4, 2016 Author Share Posted September 4, 2016 (edited) thank you it was just the folder wrong, but yet even if I upload it, the rocks are still the same even with that expression. can you tell me why? Is something wrong with that? :\ my rockNumvalue is ceil(rand($PT)*99) Edited September 4, 2016 by lyansart Quote Link to comment Share on other sites More sharing options...
f1480187 Posted September 4, 2016 Share Posted September 4, 2016 Expression looks perfectly fine for me. Can you post file? 1 Quote Link to comment Share on other sites More sharing options...
Atom Posted September 4, 2016 Share Posted September 4, 2016 (edited) I thought you needed quotes around the variable name as well in a stamp? padzero(3, stamp("../copy1", "rockNum", 1)) Edited September 4, 2016 by Atom 1 Quote Link to comment Share on other sites More sharing options...
lyansart Posted September 4, 2016 Author Share Posted September 4, 2016 I've tried but nothing changes. sure I can, but there is a lot of files (as long I've created a lot of rocks) So.. I can post them all, hoping that's okay. thank you so much. sasso_001.bgeo sasso_002.bgeo sasso_003.bgeo sasso_004.bgeo sasso_005.bgeo sasso_006.bgeo sasso_007.bgeo sasso_008.bgeo sasso_009.bgeo sasso_010.bgeo sasso_011.bgeo sasso_012.bgeo sasso_013.bgeo sasso_014.bgeo sasso_015.bgeo sasso_016.bgeo sasso_017.bgeo sasso_018.bgeo sasso_019.bgeo sasso_020.bgeo sasso_021.bgeo sasso_022.bgeo sasso_023.bgeo sasso_024.bgeo sasso_025.bgeo sasso_026.bgeo sasso_027.bgeo sasso_028.bgeo sasso_029.bgeo sasso_030.bgeo sasso_031.bgeo sasso_032.bgeo sasso_033.bgeo sasso_034.bgeo sasso_035.bgeo sasso_036.bgeo sasso_037.bgeo sasso_038.bgeo sasso_039.bgeo sasso_040.bgeo sasso_041.bgeo sasso_042.bgeo sasso_043.bgeo sasso_044.bgeo sasso_045.bgeo sasso_046.bgeo sasso_047.bgeo sasso_048.bgeo sasso_049.bgeo sasso_050.bgeo sasso_051.bgeo sasso_052.bgeo sasso_053.bgeo sasso_054.bgeo sasso_055.bgeo sasso_056.bgeo sasso_057.bgeo sasso_058.bgeo sasso_059.bgeo sasso_060.bgeo sasso_061.bgeo sasso_062.bgeo sasso_063.bgeo sasso_064.bgeo sasso_065.bgeo sasso_066.bgeo sasso_067.bgeo sasso_068.bgeo sasso_069.bgeo sasso_070.bgeo sasso_071.bgeo sasso_072.bgeo sasso_073.bgeo sasso_074.bgeo sasso_075.bgeo sasso_076.bgeo sasso_077.bgeo sasso_078.bgeo sasso_079.bgeo sasso_080.bgeo sasso_081.bgeo sasso_082.bgeo sasso_083.bgeo sasso_084.bgeo sasso_085.bgeo sasso_086.bgeo sasso_087.bgeo sasso_088.bgeo sasso_089.bgeo sasso_090.bgeo sasso_091.bgeo sasso_092.bgeo sasso_093.bgeo sasso_094.bgeo sasso_095.bgeo sasso_096.bgeo sasso_097.bgeo sasso_098.bgeo sasso_099.bgeo sasso_100.bgeo rock_doesntvariate.hipnc Quote Link to comment Share on other sites More sharing options...
f1480187 Posted September 4, 2016 Share Posted September 4, 2016 There was a typo in rockNum stamp expression (extra multiplication operator). And maybe an extra "rocks" folder in path, if you have no such structure inside your hip folder. Also make sure you checked Stamp Inputs on Copy node to use stamp. It won't throw an error, but will use default value (which is number "1" in stamp function call - check documentation about it). Here is working example. stamping_geo.zip Quote Link to comment Share on other sites More sharing options...
lyansart Posted September 5, 2016 Author Share Posted September 5, 2016 10 hours ago, f1480187 said: There was a typo in rockNum stamp expression (extra multiplication operator). And maybe an extra "rocks" folder in path, if you have no such structure inside your hip folder. Also make sure you checked Stamp Inputs on Copy node to use stamp. It won't throw an error, but will use default value (which is number "1" in stamp function call - check documentation about it). Here is working example. stamping_geo.zip Thank you SO much, it's working for me too now. I'm sorry I'm losing myself on those stupid errors. Thank you again Quote Link to comment Share on other sites More sharing options...
