How would you animate growing siv from point a to b?
ISUther
Hello,
I am trying to figure out what node to use in order to build 25% circle from point a to point b
1.) I created Geo node and dived inside
2.) I deleted original node and created Circle node
3.) I changed circle node "Arc Angles" to 0 and -90 this way i got 25% from circle
4.) I created poly wire node and connected circle node to it.
But now i am stuck as i don`t know what node to use in order to make that 25% circle grow from nothing to 25%
and i don`t know how to make 6 wires grow from that main poly wire from specific spots
Some one can give me good hint or idea what node to use there? Or create small sample?
Best regards Tanel.V
Thank you for this.
Now i know what that node does.
Do you have any idea what node to use in order ti make the curve end (tip) thinner then the other end so it goes like smoothly thick on one end and thinner on another?
And how to connect or mark specific points in that curve so that from those specific spots i start grow smaler stivs?
add an attribute wrangle and add this
@Cd.r = 1-@ptnum/float(@numpt);
then in your polywire, on the wire radius you can add this
@Cd.r*.01
Also you can use an AtrributeVop to have more control with a Ramp parameter
Edited by Sepu
