Configure Wind Force (To Act More Like Real Wind)?
Atom
Hi All,
I have always been disappointed by all 3d packages ability to emulate wind. Sure, most make something called wind but it is just a re-packaged noise generator. Does anyone have any better recipes for emulating wind?
PopWind does have a velocity direction field, but I don't feel like it outputs the ebb and flow that defines natural wind.
Let's pretend we want wind to blow from East to West so we setup a velocity in the X axis. But wind is not a fan. A fan would blow continuously in one direction, but wind kind of pushes then stops, maybe flows a little the opposite direction then takes off in the direction again.
Can PopWind be configured to act more like wind and less like a fan?
I have attached the setup I am working with. Basically some instanced spheres floating in a volume.
ap_geo_in_slow_floating_volume_101816.hipnc
That might help out, use two.
I kind of headed down a similar path, combining multiple forces, using CHOPS to create a more random motion with lag. Instead of using PopWind, I use PopDrag and set the direction equal to the output from the CHOPs. Because the Air Resistance seems to just be a multiplier on Wind Direction per axis you can use VEX to randomize the strength of the air resistance on a per-particle basis. This gives a kind of suspended in gel motion that still follows the master noise generator.
ap_chop_wind_101816.hipnc
