[novice] FLIP sim- how to properly change scale
art3mis
Hi
In a FLIP sim I am working on the scale seems way off, ie too much detail and small droplets in the splashes.
So I have tried simply reducing the Uniform Scale value of all my geo objects, including the fluidtank_fluid at the obj level. But this doesn't seem to work and introduces strange errors.
Don't scale the fluid tank, it should remain at a scale of 1.0. Resize the initial fluid inside the tank instead. Beware, larger fluid areas require smaller particle separations to cover the same area.
