Houdini hair problem
sinarhp
Hi everyone
I just recently started playing around with Houdini hair after finishing a very difficult job done with Yeti.
I am trying to assess houdini hair as a possible new solution for hair and fur.
But I have one small issue that I cant find any solutions for it:
Basically after setting up the fur for the model (I am using the Add Fur tool from the shelf) everything is fine and I can use the different attributes like length and bend to adjust the overall look,
But as soon as I groom the fur using one of the shelf tools like "length adjust" or "cut hair" I cant tweak the overall attributes like length or bend etc anymore and it seems like after grooming the hair using any of these tools I lose the ability to adjust the overall attributes.
I was wondering if this is probably a bug in hair tool?
I have attached my test scene as well.
I would appreciate any helps.
Thanks in advance!
Sina
fur_pipe_test_01_v01_t05.hip
  • 4 weeks later...
On 24/10/2016 at 7:40 AM, sinarhp said:
Hi everyone
Thanks in advance!
Sina
I played around with fur a bit and had the same problem. grooming just instantly disables changing any parameters. weird.
