CHOPs, VEX and the future of chops in Houdini
ikoon
I am looking for a VEX equivalent of chop() expression.
I have tried the ch() function as attached. I know, that ch() in the Wrangle is usually used to read the Parameter from the Interface. But the help file says "Evaluates a channel (or parameter) and return its value."
Am I close, please? What is the best practice for this?
vex read chop.hiplcFetching info...
Edited by ikoon
Thank you very much! I have tried these approaches:
A] backtick method
- unfortunately it seems to evaluate only on the first frame
B] export chop
- I have tried to make it "automatic" with this code in the export chop: `run("chopls ../OUT")`
- everything works fine, but if I add channel, I have to restart Houdini (or delete/undo the chopnet) to make that `run` code initialize (you can see the attachment and try to add more channels).
C] channel sop and geometry sop
- this combination is great, but what if I would like to have just one channel to affect one detail attribute and not to evaluate all the points?
It seems to me, that CHOPnet in Houdini is quite "abandoned area".
Am I right? I am quite new to Houdini. Everything seems to be a workaround in chops:
- for example the `run(chopls)` backtick listing, generated by Motion FX. It is a combination of HScript() and Expression language
- also that UI message "Overridden by /obj/geo1/chopnet1/export1"
- it seems, that there is no vex equivalent of chop() expression
I would love to use chops to make the animations visually appealing using chops and these principes. I think that these principles work not only in the cartoon, but also in VFX and Motion design:
http://the12principles.tumblr.com/post/84179271499/anticipation
http://the12principles.tumblr.com/post/84177204689/follow-through-overlapping
http://the12principles.tumblr.com/post/84179300674/squash-stretch
What do you think will be the future of Chops? I mean, is there a market for these simple "nonvfx" chops/vex? Are people using it? I see the chops to be somehow distracted (motion fx / agents / animation layers / ui implementation). On one hand, CHOPs seem to be everywhere in Houdini, but on the other hand ... that `run("chopls ../OUT")`
vex read chop - A - backtick - v0.hiplcFetching info...
vex read chop - B - export chop - v0.hiplcFetching info...
Edited by ikoon
  • 4 months later...
I have tried this new VEX function "chattr" but unfortunately I have not succeeded:
https://www.sidefx.com/docs/houdini/vex/functions/chattr
It is strange, that I got "undefined function" error. I think I am doing it wrong, but also ... isn't it a bug? I am not that skilled to decide.
Edited by ikoon
Dedeks, you are right. In the Channel Wrangle, the function is working.
So my old question probably remains unanswered with H16 ... or can we reference CHOP directly from the SOP wrangle in H16?
For me , the Atom method seems OK but instead of using the export flag in your parm , just use the chop() expression directly ,
and in your code just reference your parm with ch() expr.
Concerning CHOP and his future , Houdini 16 come with  really good stuff ,  look at the constraint system and  the channel Wrangle .
On the other hand,  accessing chop data directly from vex  code would be great :)
vex read chop.hipncFetching info...
Edited by dedeks3000
correction
  • 1 year later...
