DeviousShadows Posted January 10, 2017 Share Posted January 10, 2017 Hi everyone! I just registered on this website, do pardon my lack of experience with houdini! I'm currently trying to produce an ash effect. What I did was use attribtransfer to make the faces of a mesh to separate. The floating effect was done using the voronoifracture node and the spring node. I got the result I wanted, the faces rising up as the fire spreads across the object. What I am trying to achieve right now is have the different faces shrink over time. Does anyone know how this can be done? Also, how should I go about doing the shader? Is there a way to make the edges of a mesh glow? Quote Link to comment Share on other sites More sharing options...
haggi Posted January 10, 2017 Share Posted January 10, 2017 (edited) To scale the primitives you have several ways. One is to use a foreach loop. Just use it as it is you only have to turn off the "Piece Attribute" checkbox. Then you can plug a transform node into the middle of the foreach loop and scale the primitives after setting the pivot to the center of the primitive, e.g. with $CEX, $CEY and $CEZ. Or you can create packed objects from the primitives with the help of an assemble node. Then you can set the primintrinsic called "transform" to a desired value like this: matrix3 m3; m3 = ident(); vector s = set(.5, .5, .5); scale(m3, s); setprimintrinsic(0, "transform", @primnum, m3); Or you can use a primitive sop and use the transformation there. (added this before it was mentioned below..). Edited January 10, 2017 by haggi Quote Link to comment Share on other sites More sharing options...
Skybar Posted January 10, 2017 Share Posted January 10, 2017 6 minutes ago, haggi said: To scale the primitives you have several ways. One is to use a foreach loop. Just use it as it is you only have to turn off the "Piece Attribute" checkbox. Then you can plug a transform node into the middle of the foreach loop and scale the primitives after setting the pivot to the center of the primitive, e.g. with $CEX, $CEY and $CEZ. You can use a Primitive SOP for this, to avoid using foreach. Quote Link to comment Share on other sites More sharing options...
