cgartashish Posted January 27, 2017 Share Posted January 27, 2017 Hi, I had created a sphere and then fractured it, then I had selected few pieces so that I could copy them randomly onto few particles/points via the copy sop. The problem is that, I want the copy sop to randomly pick up any one piece out of my selected pieces say from "piece0" to "piece8". But what actually happens is either only one piece is copied to each point/particles or all the eight pieces are cluttered together and copied over each point. How can I set up a workflow where the copy sop randomly picks up any one piece from the provided pieces from the fractured geometry and instances it onto random points? Thanks. Quote Link to comment Share on other sites More sharing options...
shawn_kearney Posted January 27, 2017 Share Posted January 27, 2017 (edited) I'm pretty new with houdini, so I am sure there is a better way. randomselection.hiplc Edited January 27, 2017 by shawn_kearney Quote Link to comment Share on other sites More sharing options...
vtrvtr Posted January 27, 2017 Share Posted January 27, 2017 (edited) This is possible, but I think it's a bit of work. Wouldn't be better to use stamp to vary the pieces instead (with a mountain sop or something)? Anyway, if you really want to copy the fractured pieces you can pack it and then use the blast sop to delete everything but some fractured piece. Like this In the actual copy sop you can define the limits of the random to only the pieces you want (although I think it's easier to just delete the pieces you don't want the random to pick from) Edited January 27, 2017 by vtrvtr 1 Quote Link to comment Share on other sites More sharing options...
cgartashish Posted January 28, 2017 Author Share Posted January 28, 2017 Thanks alot, your way works but I am really confused. Is there any other way? Quote Link to comment Share on other sites More sharing options...
cgartashish Posted January 28, 2017 Author Share Posted January 28, 2017 (edited) 7 hours ago, vtrvtr said: This is possible, but I think it's a bit of work. Wouldn't be better to use stamp to vary the pieces instead (with a mountain sop or something)? Anyway, if you really want to copy the fractured pieces you can pack it and then use the blast sop to delete everything but some fractured piece. Like this In the actual copy sop you can define the limits of the random to only the pieces you want (although I think it's easier to just delete the pieces you don't want the random to pick from) Hi, Thanks a lot for your help. It even works with the delete sop but I am really confused, because this expression works perfectly when I put it in group parameter of delete sop but when I put it in pattern parameter then the expression copies one single piece of geo onto every points. Why is that? How does it works in group parameter? Can you please explain? Edited January 28, 2017 by cgartashish Some more info to add Quote Link to comment Share on other sites More sharing options...
shawn_kearney Posted January 28, 2017 Share Posted January 28, 2017 Slight improvement to my version to account for part the centering of pieces, and got rid of some weirdness in VOP. Not sure if this is possible without a for-each (is it?). Mine works by attributing one random piece to a group called "sel" and using that group to define the source group on the copy SOP. The seed for the random selection is based on the point number of the template point. This point number though is lost inside the for-each since it only brings in one point at a time, so it must be written to the "id" point attribute piror. I then multiplied the random number generated (which is between 0-1) by the total number of packed primitives and converted it to an integer. Now I have a random integer that corresponds to a single packed primitive. I use this index number to assign the primitive to the group "sel" So for this iteration I have one randomly selected packed primitive belonging to the group "sel" which I can use as the source group. In practice I'd probably do it a little differently and instead delete all but the selected and transform to the point, orienting to normal if needed and skipping the copy sop entirely. randomselection.hiplc 1 Quote Link to comment Share on other sites More sharing options...
Skybar Posted January 28, 2017 Share Posted January 28, 2017 7 hours ago, shawn_kearney said: Not sure if this is possible without a for-each (is it?). Sure: randomselection_dv.hiplc Option1 uses Primitive SOP to put the pieces on the points. I use a few nodes and expressions before that to make sure we have as many primitives as we have points - if we have to few, not all points are gonna get a primitive - and if we have to many, some primitives won't be moved. Option2 uses Primitive SOP to put everything at the origin, and then just copystamp. I added some animation to the points so you can see the speed difference between the different methods. Increase the points on the scatter to like a thousand, and you can see option2 starting to become slower while option1 doesn't as much. The Primitive SOP might be quite limited in terms of control versus the Copy SOP, so what you use mostly depends on what you need. Also, a good alternative to the Prim SOP in option1 is to use Transform Pieces SOP. 1 Quote Link to comment Share on other sites More sharing options...
vtrvtr Posted January 28, 2017 Share Posted January 28, 2017 @cgartashish The pattern field in the delete sop doesn't work with vex variables (@name, in this case) groups do (I would think in all sops, but don't quote me on that) However, because of the nature of this particular issue, you can use the Pattern field too This works because you can delete the packed primitives by their point number 1 Quote Link to comment Share on other sites More sharing options...
shawn_kearney Posted January 28, 2017 Share Posted January 28, 2017 1 hour ago, Skybar said: Sure: randomselection_dv.hiplc Option1 uses Primitive SOP to put the pieces on the points. I use a few nodes and expressions before that to make sure we have as many primitives as we have points - if we have to few, not all points are gonna get a primitive - and if we have to many, some primitives won't be moved. Option2 uses Primitive SOP to put everything at the origin, and then just copystamp. I added some animation to the points so you can see the speed difference between the different methods. Increase the points on the scatter to like a thousand, and you can see option2 starting to become slower while option1 doesn't as much. The Primitive SOP might be quite limited in terms of control versus the Copy SOP, so what you use mostly depends on what you need. Also, a good alternative to the Prim SOP in option1 is to use Transform Pieces SOP. I figured my method would be inefficient since I had to copy all the geometry for each iteration. I'll be sure to take a look at your hip later. Quote Link to comment Share on other sites More sharing options...
