qazwsdc Posted February 10, 2017 Share Posted February 10, 2017 (edited) Anyone have a tutorial of this effects? Really need help. Edited February 21, 2017 by qazwsdc Quote Link to comment Share on other sites More sharing options...
confusedlittleman Posted February 10, 2017 Share Posted February 10, 2017 Looks a lot like particles with additive shading that are driven along curves/ advected by volumes. If you search for beam effect, magic spell, magic effects, additive shading etc. you will find a lot of good starting points. But as always in houdini there's a ton of creative ways to achieve this certain kind of look. You could also try to use curves themselves with different width, animated noise and render them with additive shading. cheers Quote Link to comment Share on other sites More sharing options...
Atom Posted February 11, 2017 Share Posted February 11, 2017 Check out this tutorial. Quote Link to comment Share on other sites More sharing options...
qazwsdc Posted February 21, 2017 Author Share Posted February 21, 2017 On 2017/2/11 at 0:40 AM, confusedlittleman said: Looks a lot like particles with additive shading that are driven along curves/ advected by volumes. If you search for beam effect, magic spell, magic effects, additive shading etc. you will find a lot of good starting points. But as always in houdini there's a ton of creative ways to achieve this certain kind of look. You could also try to use curves themselves with different width, animated noise and render them with additive shading. cheers Can you tell me a little bit more about this effects such as use curves?Hopefully hip files.Thank you very much Quote Link to comment Share on other sites More sharing options...
qazwsdc Posted February 21, 2017 Author Share Posted February 21, 2017 On 2017/2/11 at 10:49 PM, Atom said: Check out this tutorial. I think the "pop curve force" is dificult to use.It's very easy to lose particles and hard to control particles.It's hard to hold all particles if the curve have a big arc. Quote Link to comment Share on other sites More sharing options...
paranoidx Posted September 2, 2020 Share Posted September 2, 2020 try pop attraction Quote Link to comment Share on other sites More sharing options...
