Georgio Buloso Posted February 14, 2017 Share Posted February 14, 2017 hey fellow houdini artists hope that you are doing great today! i recently just notice that my houdini is having to cook everytime i lay down a node a.e geo grid sphere...... and its taking too long to select any node by right click, so i am having to highight the node everytime i wanna select it? .never used to do this... thought i should shoot a question about this thanks Quote Link to comment Share on other sites More sharing options...
Atom Posted February 14, 2017 Share Posted February 14, 2017 You must have a dop or pop net inside your network that thinks it needs to revise itself. If you know you are going to change a few things in the network and each change is going to require a new cook then move your mouse to the lower right-hand corner of Houdini and click on AutoUpdate. Change it to Manual. Then you can freely make multiple changes to the current network without incurring the penalty of a cook on each change. After you have made all the changes, switch it back to AutoUpdate to restore normal operations. I have been using this feature a lot more as I work with FLIP. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted February 14, 2017 Share Posted February 14, 2017 also make sure the Render View isn't processing on another tab. Quote Link to comment Share on other sites More sharing options...
Georgio Buloso Posted February 15, 2017 Author Share Posted February 15, 2017 @Atom @marty thanks alot guys for trying to help @Atom i just tried exactly what you said there's no change at all it's still the same! @marty render view isnt processing at , guys is there any other way around this ?? thanks alot Quote Link to comment Share on other sites More sharing options...
Jero3d Posted February 15, 2017 Share Posted February 15, 2017 I had similar problems over the weekend and updating my graphics card driver solved it for me Quote Link to comment Share on other sites More sharing options...
Diego A Grimaldi Posted February 15, 2017 Share Posted February 15, 2017 @Georgio Buloso how about checking your performance monitor and see what nodes are bugging and slowing down your network? That's not a normal Houdini behavior...Does it happen if you close and open a fresh Houdini session? If so you might wanna submit and RFE Quote Link to comment Share on other sites More sharing options...
foxel Posted February 15, 2017 Share Posted February 15, 2017 (edited) I noticed a difference on my windows 10 laptop on the weekend as well. Creating a box would take a minute, selecting and moving nodes would be a complete pain. I checked for latest drivers but there were none available. Everything was working fine before. Any ideas? Edited February 15, 2017 by foxel Quote Link to comment Share on other sites More sharing options...
Jero3d Posted February 15, 2017 Share Posted February 15, 2017 (edited) Foxel try reinstalling your current graphics card driver if you can't update it. I had the exact same issue during the weekend on my windows 10 laptop. After submitting a bug report, SideFX replied saying I should reinstall or upgrade my graphics card driver. I did that and it immediately worked again. I had tried EVERY possible solution before that. I uninstalled Houdini several times, deleted the houdini15.5 folder, disabled my anti virus, disabled/enabled the firewall for Houdini, even tried to launch Houdini while offline and nothing seemed to fix it. At one point I even suspected something could be wrong with my RAM since it wouldn't go above 4gb (out of 16) while it was cooking a big scene. No matter what I did in Houdini the memory wouldn't go above 4gb. I ran the windows memory diagnostic tool and had no errors, so I knew it wasn't a hardware issue. The only thing that solved it was reinstalling the graphics card driver. If that doesn't help I would submit a bug to SideFX! Edit: To reinstall the latest driver, I actually went into Nvidia's website and downloaded the driver myself, instead of updating it from the Nvidia control panel. My guess is that some update on Windows 10 might have corrupted the driver. Edited February 15, 2017 by Jero3d 1 Quote Link to comment Share on other sites More sharing options...
Georgio Buloso Posted February 15, 2017 Author Share Posted February 15, 2017 @Jero3d thanks a lot i have just updated my graphic card all went back to normal thanks for your help!!! @ dmitri if you using a gforce driver uninstall it and download and instal it again @Diego A Grimaldi thanks for shout that out i think it was something to do with graphic card but thanks though really appreciate your efforts guys 1 Quote Link to comment Share on other sites More sharing options...
foxel Posted February 16, 2017 Share Posted February 16, 2017 2 hours ago, Jero3d said: Foxel try reinstalling your current graphics card driver if you can't update it. I had the exact same issue during the weekend on my windows 10 laptop. After submitting a bug report, SideFX replied saying I should reinstall or upgrade my graphics card driver. I did that and it immediately worked again. I had tried EVERY possible solution before that. I uninstalled Houdini several times, deleted the houdini15.5 folder, disabled my anti virus, disabled/enabled the firewall for Houdini, even tried to launch Houdini while offline and nothing seemed to fix it. At one point I even suspected something could be wrong with my RAM since it wouldn't go above 4gb (out of 16) while it was cooking a big scene. No matter what I did in Houdini the memory wouldn't go above 4gb. I ran the windows memory diagnostic tool and had no errors, so I knew it wasn't a hardware issue. The only thing that solved it was reinstalling the graphics card driver. If that doesn't help I would submit a bug to SideFX! Edit: To reinstall the latest driver, I actually went into Nvidia's website and downloaded the driver myself, instead of updating it from the Nvidia control panel. My guess is that some update on Windows 10 might have corrupted the driver. Thank you for your help, I will try that as soon as I get home. I tried all the things you tried before giving up - only came short of reinstalling drivers. Thanks again Quote Link to comment Share on other sites More sharing options...
foxel Posted February 16, 2017 Share Posted February 16, 2017 43 minutes ago, Georgio Buloso said: @Jero3d thanks a lot i have just updated my graphic card all went back to normal thanks for your help!!! @ dmitri if you using a gforce driver uninstall it and download and instal it again @Diego A Grimaldi thanks for shout that out i think it was something to do with graphic card but thanks though really appreciate your efforts guys Thank you! As soon as I get home I'll do that. Very happy that there is a solution Quote Link to comment Share on other sites More sharing options...
Atom Posted February 16, 2017 Share Posted February 16, 2017 If switching to Manual has no effect then you must have a File node somewhere in there that is fetching a ton of data. Quote Link to comment Share on other sites More sharing options...
Georgio Buloso Posted February 16, 2017 Author Share Posted February 16, 2017 @Atom thanks Quote Link to comment Share on other sites More sharing options...
foxel Posted February 16, 2017 Share Posted February 16, 2017 Reinstalling the drivers has fixed the issue. Thanks! Quote Link to comment Share on other sites More sharing options...
